1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Long expressions using MAX and MIN in CALC fields
To: "'Tim Mooney'" <[email protected]>
Cc: "Tech-Talk (E-mail)" <[email protected]>
Date: Thu, 27 Feb 2003 10:05:47 -0800
Dear Tim,
Ah yes, the operator priorities!  I had not stared sufficiently deeply into
the code to understand how they were used.  In practice, I would almost
always put parentheses around an expression using unfamiliar operators.
However, when every character counts, it is best to assign the priorities
correctly!  I would vote for priorities 5, 5 like multiplication.
I am intrigued by your exploration of variable argument lists.  If you can
make this work robustly, it is clearly the best approach.  Rock on!
Dr. Russell O. Redman
Tel: (250) 363-6917 | Fax: (250) 363-0045
<mailto:[email protected]>
National Research Council Canada | Conseil national de recherches Canada
5071 West Saanich Road           | 5071 West Saanich Road
Victoria, B. C. V9E 2E7          | Victoria, C.-B. V9E 2E7
Government of Canada             | Gouvernement du Canada
> -----Original Message-----
> From: Tim Mooney [mailto:[email protected]]
> Sent: Wednesday, 2003 February 26 8:46 PM
> To: Redman, Russell O.
> Cc: Tech-Talk (E-mail)
> Subject: Re: Long expressions using MAX and MIN in CALC fields
> "Redman, Russell O." wrote:
> > I would like to suggest a small enhancement for the calcRecord,
> > My motivation for this change is that I would like to use a
> SINGLE calcout
> > record to evaluate
> >   MIN(2,MAX(A,B,C,D,E,F,G,H,I))
> > A much easier approach to implement is to treat MAX and MIN
> as binary
> > operators.
> > ...I suggest that "|<" and ">|"
> > might be suitable as binary MIN and MAX operators, respectively.
> > In the postfix.c code, insert the two lines
> > {">|",  7, 8,      BINARY_OPERATOR, MAX}, /* maximum of 2 args */
> > {"|<",  7, 8,      BINARY_OPERATOR, MIN}, /* minimum of 2 args */
> Cool, but the parsing priorities (7,8) are too high.  "tan(a) >| b"
> actually
> gets evaluated as "tan(max(a,b))" -- REALLY not what you want!  Also,
> with
> (in-stack==7, incoming==8), the operators will associate from right to
> left.
> I think most folks would expect them to associate from left
> to right, as
> and "-" do.
> I think a better set of priorities would be either (4,4) -- like
> addition --
> or (5,5) -- like multiplication.
> Anyway, I got interested in playing around with a variable number of
> arguments,
> and found that calcPostfix() actually accepts "max(a,b,c)",
> and produces
> postfix
> for it, though calcPerform() doesn't know what to do with the postfix
> expression,
> and returns an error because its value stack doesn't end up empty.
> However,
> "max(a,b,min(c))" gets by both of these guys, because the total number
> of
> arguments matches the total number consumed by operators, and it
> produces the same
> result as "max(a,min(b,c))"!  Odd, but innocuous, I'm convinced: stack
> overflow
> is not a problem because the stack already has to be large enough for
> the worst-case
> expression, and an infix expression that would produce a
> stack underflow
> in
> calcPerform would not have enough operands to pass
> calcPostfix()'s final
> test.
> I don't think we're just lucky.  I think the person who wrote
> this knew
> it was ok
> to test only for missing operands.
> In all this messing around, I did get find a nice way to implement
> max(a,b,c,...),
> with two or more args.  sCalcPostfix shoves an end-of-operands symbol
> into the
> postfix expression when it sees MAX or MIN, and when sCalcPerform sees
> that, it shoves
> a NaN onto the value stack as a final operand not to be used.
>  (Yeah, I
> know...What
> happens to a badly formed expression on a PPC?  It might be better to
> use a union
> instead of NaN.)  The code isn't ready for posting yet, and I haven't
> really tried
> hard to break it.
> Tim Mooney
Prev: Re: Long expressions using MAX and MIN in CALC fields Tim Mooney
Next: Re: Long expressions using MAX and MIN in CALC fields Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Long expressions using MAX and MIN in CALC fields Redman, Russell O.
Next: GPIB Driver for SCPI commands to an Ethernet device like Keithley 2701 Multimeter Allison, Stephanie
