1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS / file load interaction problem
To: "'Erik Johansson'" <[email protected]>, "'tech-talk \(E-mail\)'" <[email protected]>
Date: Thu, 10 Apr 2003 13:49:27 -0600
Did you try increasing the number of mbufs for your vxWorks
systems IP kernel?
Jeff
> -----Original Message-----
> From: Erik Johansson [mailto:[email protected]]
> Sent: Thursday, April 10, 2003 1:43 PM
> To: tech-talk (E-mail)
> Subject: EPICS / file load interaction problem
> Hello again -
>  A follow-up on my previous posting regarding the problem of
> reading
> NFS-mounted files on an IOC while EPICS is running:
> I thoroughly investigated our network to make sure that there
> were no
> network problems causing the poor file-load performance. I also
> tried
> running my file-load code snippet on other IOCs in our system,
> with no
> change in behavior. Finally, and most interesting, I set up a
> bare-bones IOC
> in our electronics lab and was able to reproduce the problem.
> There are 4
> linked soft records, one of which is scanned at 0.5 seconds.
> After IOC init,
> my file read routine works just fine until I run camonitor on
> one of the
> channels. As soon as camonitor begins, the file load problems
> occur. I don't
> understand the underlying mechanism of monitors, but I am
> hoping that this
> is the key to the file load problems.
> Does anyone understand monitors enough to explain why they
> would interfere
> with the reading of an NFS-mounted file? And, more importantly,
> is there
> anything I can do to fix the problem?
> Any help you can give me is greatly appreciated.
> Erik
> Erik M. Johansson
> Adaptive Optics Software Engineer
> W. M. Keck Observatory
> 65-1120 Mamalahoa Hwy
> Kamuela, HI 96743
> Tel: 808-885-7887
> Fax: 808-885-4464
EPICS / file load interaction problem Erik Johansson
Prev: EPICS / file load interaction problem Erik Johansson
Next: OSI bumples reboot (R3.14.1) Dylan Maher Loughnan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
