1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building 3.14.1 under cygwin environment
To: Chris Mayer <[email protected]>
Cc: [email protected]
Date: Fri, 25 Apr 2003 12:56:48 -0500
Chris Mayer wrote:
I have been trying to build Epics 3.14.1 under the cygwin environment
on a win98 machine using gcc. The EPICS_HOST_ARCH is win32-x86-cygwin
 Everything goes well until trying to compile fdmgr.cpp when I get the
set of messages below. Has anyone else seen this (and hopefully solved
it) ?
In file included from ../../../src/libCom/fdmgr/fdmgr.cpp:29:
...../../../src/libCom/fdmgr/fdManager.h:93: parse error before `[' token
make[3]: *** [fdmgr.o] Error 1
make[2]: *** [install.win32-x86-cygwin] Error 2
make[1]: *** [libCom.install] Error 2
make: *** [src.install] Error 2
What I usually do in situations like this is to issue the compile command with -c changed to -E so I can see exactly what's getting passed on from the preprocessor to the compiler. The offending line is:
fd_set fdSets[fdrNEnums];
This makes me think that the likely cause of the problem is that
1) fd_set is not typefed properly. (to check, run the output of the '-E' compile through 'grep fd_set'.
OR
2) fdSets is being defined as a preprocessor macro somewhere in some cygwin header file. About the only thing to do here is to 'grep fdSets' on all the header files.
BTW -- is EPICS likely to work on win98???
Eric Norum                                 [email protected]
Advanced Photon Source                     Phone: (630) 252-4793
Argonne National Laboratory
Re: Building 3.14.1 under cygwin environment Chris Mayer
Prev: Building 3.14.1 under cygwin environment Chris Mayer
Next: Re: Building 3.14.1 under cygwin environment Chris Mayer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
