Eric Norum wrote:
> What I usually do in situations like this is to issue the compile
> command with -c changed to -E so I can see exactly what's getting passed
> on from the preprocessor to the compiler. The offending line is:
> fd_set fdSets[fdrNEnums];
> This makes me think that the likely cause of the problem is that
> 1) fd_set is not typefed properly. (to check, run the output of the
> '-E' compile through 'grep fd_set'.
> OR
> 2) fdSets is being defined as a preprocessor macro somewhere in some
> cygwin header file. About the only thing to do here is to 'grep fdSets'
> on all the header files.
> BTW -- is EPICS likely to work on win98???
Thanks for the tips I'll give that a try. Does anyone know the answer
to Eric's question about win98 ? This is my first foray into running
Epics/Channel Access from a Windows environment so any help would be
appreciated. Also, does anyone know what the situation is with XP ?
Chris Mayer
_______________________________________________________________________
Observatory Sciences Ltd. Email: [email protected]
William James House Tel: 44 - (0)1223 - 508257
Cowley Road, Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK http://www.observatorysciences.co.uk
- RE: Building 3.14.1 under cygwin environment Jeff Hill
- Building 3.14.1 under cygwin environment Chris Mayer
- Re: Building 3.14.1 under cygwin environment Eric Norum
RE: Building 3.14.1 under cygwin environment Redman, Russell O.
<2003>
2025
2026
<2003>
2025
2026
