"excas" does not compile/install if installing R3.14.2 in other than the source (default) directory. =============================================================== If, during the first compile, I change INSTALL_LOCATION in base-3.14.2/configure/RELEASE.linux-x86 from the default #INSTALL_LOCATION=<fullpathname> to INSTALL_LOCATION=/usr/local/epics-3.14.2 I get the following errors near the completion of compiling epics: gmake[3]: Entering directory `/home0/bra/EPICS/src/R3.14.2/base-3.14.2/src/excas/O.linux-x86' gmake[3]: Leaving directory `/home0/bra/EPICS/src/R3.14.2/base-3.14.2/src/excas/O.linux-x86' gmake[3]: Entering directory `/home0/bra/EPICS/src/R3.14.2/base-3.14.2/src/excas/O.linux-x86' gmake[3]: *** No rule to make target `main.o', needed by `excas'. Stop. gmake[3]: Leaving directory `/home0/bra/EPICS/src/R3.14.2/base-3.14.2/src/excas/O.linux-x86' gmake[2]: *** [install.linux-x86] Error 2 gmake[2]: Leaving directory `/home0/bra/EPICS/src/R3.14.2/base-3.14.2/src/excas' gmake[1]: *** [excas.install] Error 2 gmake[1]: Leaving directory `/home0/bra/EPICS/src/R3.14.2/base-3.14.2/src' gmake: *** [src.install] Error 2
I am using Redhat Linux 7.3 and 8.0 on an i686. Other configuration files were modified from working epics-3.14.1 files Questions:
1. Does my way of getting excas compiled and moved give the desired
results?2. What modifications would allow "excas" to compile and install
correctly the first time when not installing in the default
directory?Thanks, Billy Adams <mailto:[email protected]> Raytheon Technical Services Assigned to: Research Facilities Branch of Research Facilities Management Office 16 Victory Street Mail Stop 413 Building 1251, Room 126D NASA Langley Research Center Hampton, Va. 23681-2199 Phone 1-757-864-6242 Fax 1-757-864-8095
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
