The "select" record in base can select the highest value of 12 inputs.
Configuring a select record in which each input is another select record
would give you the highest value of 144 PVs ...
Ned
Tim Mooney wrote:
re...,
John K Munro Jr wrote:
Hi Ernest,
Is there a way (that someone has already implemented) with EPICS to
monitor a set of a large number (many dozens) of PVs used for readback
for the maximum (minimum) value in the set and to report the result? I
would like to be able to display such a maximum (minimum) as part of
giving information about the status of equipment to the operator.
The most straight-forward solution might be to use a bunch of calcOut
records.
Twelve of them would, in principle, handle 11 dozen PV's. However, with
the
calc software currently in base, you can only compute the max of five (or
maybe six) PV's per calc record, because the calc string is limited in
size,
and because you have to say something like "max(max(a,b),max(c,d))...
With newer calc software (currently in beta test) --
www.aps.anl.gov/xfd/SoftDist/swBCDA/postfix_R3.13.5.tar.gz
-- you can say "max(a,b,c,d,e,f,g,h,i,j,k,l)", and get 12 PV's per record.
Another straight-forward solution is SNL code, which would execute
more quickly, but be less convenient to modify or generalize.
- Maximum (Minimum) Value of a Set of Readback PVs John K Munro Jr
- Re: Maximum (Minimum) Value of a Set of Readback PVs Tim Mooney
R3.14 and registerRecordDeviceDriver Kate Feng
<2003>
2025
2026
Re: Maximum (Minimum) Value of a Set of Readback PVs kuner
<2003>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
