Hello,
I
implemented a simple sub record to read a series of individual values from
different ai records and write them into the elements of a waveform record,
the code for which is attached. It should be straightforward to use the
same method to read elements from one waveform, perform your
calculation and write the calculated values to another. Please note
that the attached code uses INPA as the address of the output waveform
record.
Hope
this helps.
Steve
Singleton
hi, all
Has anyone implemented array processing with a subroutine
record?
I want to access the values in a waveform (WFM) record with
a subroutine record, cacultate for each element and pass the array to the
output.
WFM -->|a
out|----> WFM
ai
-->|b |
ai
-->|c | for
idx=0..499
(a[idx] - b ) *
c
| SUB- |
| ROUT- |
| INE |
Jianguo
DING
SSRF, Shanghai Institute of Nuclear Research
Chinese Academy of Science
pressArray.c
Description: Binary data
Waveform calaulation for each element DING JIANGUO
Re: Waveform calaulation for each element Noboru Yamamoto
<2003>
2025
2026
Re: Waveform calaulation for each element Alexei Dmitrovski
Re: Maximum (Minimum) Vaue of a Set of Readback PVs kuner
<2003>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
