Sorry, that was indeed the outpur of the script. If I've improoved my
mail skills yet, the script should be attached now
-- [email protected] ----------- Bessy Gmbh -----------------
-- +49 30 6392 4981 ------------------ Albert Einstein Strasse 15 -
-------------------------------------- 12489 Berlin ---------------
eval 'exec perl -S $0 ${1+"$@"}' # -*- Mode: perl -*-
if $running_under_some_shell;
use strict;
# $Log$
# CreateSt.pl
# A little helper to create a snl program that watches a set of PV's and sets a
# bo record to 1 if at least one of the watched PVS is 1 and set's it to 0 if all
# PV's are 0. Needed to create a summ signal for many error conditions.
# For every state set with the functionality described above define a list of
# Variables to be monitored. Declare all of this lists in %allSig the rest is done
# by the script. It is made shure that PV's that are needed in multiple lists are
# declared and monitored only once.
# The subroutine 'stateSet' defines what to do in the state set. It can be modified
# easily.
########### define dependencies here ##########
### define a list for every state set.
my $applicationName='PPTMOD';
my @misc = qw(PPTMOD:CabDoorSw PPTMOD:EarthSw PPTMOD:EmergSw
PPTMOD:eoLineMax PPTMOD:GndRod
my @cooling = qw(PPTMOD:BodyWaFlSw PPTMOD:CavyWaFlSw PPTMOD:CircWaFlSw
PPTMOD:CollWaFlSw PPTMOD:LoadWaFlSw PPTMOD:MagnetTempSw
PPTMOD:MagnWaFlSw PPTMOD:TankTempSw PPTMOD:TankWaFlSw
### Create one state set for every list
my %allSig = ("misc" => \@misc,
"cooling" => \@cooling,
########## from now on: DON'T EDIT ##########
print "**** Creating: state machine for $applicationName application ****\n";
# Create a hash with all signals once
my %allSignals;
my $nrOfSignals=0;
foreach my $s (keys(%allSig))
my $rSig = $allSig{$s};
my %Sig;
foreach my $sig (@$rSig)
{ my $idx = $allSignals{$sig};
next if( defined $idx );
$idx = $nrOfSignals;
$nrOfSignals++;
$allSignals{$sig}=$idx;
# print "All signals and indices, $nrOfSignals\n";
# my $idx=0;
# my %revSig = reverse %allSignals;
# foreach my $pv (sort keys %allSignals){ printf ("%30s = %2d %2d = %s\n",$pv,$allSignals{$pv},$idx,$revSig{$idx}); $idx++;}
open (ST, ">$applicationName.st") or die "Can't open file: $applicationName.st: $!";
# Create header of .st file declare and monitor all PV's
print ST "program $applicationName\n".
"\n".
"int stt[$nrOfSignals];\n";
# Define one record for each state set for the output of the calculation done in the state set
print "\tcreate: $applicationName.st ($nrOfSignals signals). Need epics bo-records:\n";
foreach my $s (keys(%allSig) )
{ print ST "int $s"."On;\n"; # nameOfTheListOn
print "\t- $s"."On,\n";
print ST "\n";
foreach my $s (keys %allSig )
{ print ST "assign $s"."On \tto \"$applicationName:$s"."On\";\n";
print ST "\n/*sorted in alphabetical order of signals*/\n";
my $idx=0;
foreach my $sig (sort keys %allSignals)
{ print ST "assign stt[$allSignals{$sig}] to \t\"$sig\";\n";
#print "$sig assign stt[$idx] to \t\"$revSig{$sig}\";\n";
$idx++;
print ST "\n".
"monitor stt;\n".
"\n";
# now all PVs are declared so create a state set for every list
foreach my$sig (keys %allSig)
{ stateSet($sig, $allSig{$sig});
# Close output file
close ST or die "Can't close output file: $applicationName"."psOff.st $!\n";
# Create this state set for one list
sub stateSet
{ my($name,$rPVs) = @_; # name of the state set and PV's related to it
my $nRows = scalar(@$rPVs); # number of PV's
# init state
print ST "ss $name"."States\n".
"{\n".
" state st_$name"."Init\n".
" { when()\n".
" { $name"."On=1;\n".
" pvPut($name"."On);\n".
" } state st_$name"."On\n".
" } \n".
"\n".
" state st_$name"."Off\n".
" { when(stt[$allSignals{$rPVs->[0]}]";
# the 'one is on' state
for( $idx=1; $idx<$nRows; $idx++)
{ print ST "||stt[$allSignals{$rPVs->[$idx]}]";
print ST ")\n".
" { $name"."On = TRUE;\n".
" }\n".
"\n".
# the 'all are off' state
" state st_$name"."On\n".
" { when(!stt[$allSignals{$rPVs->[0]}]";
{ print ST "&&!stt[$allSignals{$rPVs->[$idx]}]";
print ST ")\n".
" { $name"."On = FALSE;\n".
" } state st_$name"."Off\n".
" }\n".
"}\n\n";
close ST or die "Can't close output file: $!\n";
- Re: Maximum (Minimum) Vaue of a Set of Readback PVs kuner
Setting TZ for RTEMS so that local time is correct Allison, Stephanie
Segmentation faults and the ioc example Geoff Savage
<2003>
2025
2026
<2003>
2025
2026
