My thanks to Andrew and Steve for replying.
It appears that I did not do the gmake from the <top> directory. I was
missing the O.linux-x86 in top/configure which contains
CONFIG_APP_INCLUDE. The release includes are configured from here.
Geoff
Andrew Johnson wrote:
Geoff Savage wrote:
In a Makefile at the src level how do I specify that I want the <epics
base>/include directory on the compile line?
It is by default on all C and C++ compilations, assuming you're properly
using the usual EPICS build rules (see the Makefile in the MakeBaseApp
exampleApp/src directory for the two essential include lines).
Note that the *order* of the -I options given to the compiler matches
the order of the lines in your configure/RELEASE file, where EPICS_BASE
should usually be placed last.
- Andrew
- epics base/include directory on compile line Geoff Savage
- Re: epics base/include directory on compile line Andrew Johnson
scan record john sinclair
Re: scan record Andrew Johnson
<2003>
2025
2026
<2003>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
