1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: overheads in serial communications with drvAscii, sioSup & tn etDe v
To: "Tech-Talk (E-mail)" <[email protected]>
Cc: "'Honey, Allan'" <[email protected]>, "Dunn, Jennifer" <[email protected]>, "Wooff, Robert" <[email protected]>
Date: Fri, 4 Jul 2003 16:14:15 -0700
BAAAHHH!!!
Ignore my previous message!  My previous tests of the speed of the replies
from the motor controller were misleading.  Replacing it with a loopback
connector allows the serial "communications" to run as fast as I can drive
them with no unexpected delays.  The delay must be introduced by the motor
controller, not by the code running in the IOC.
Dr. Russell O. Redman
Tel: (250) 363-6917 | Fax: (250) 363-0045
<mailto:[email protected]>
National Research Council Canada | Conseil national de recherches Canada
5071 West Saanich Road           | 5071 West Saanich Road
Victoria, B. C. V9E 2E7          | Victoria, C.-B. V9E 2E7
Government of Canada             | Gouvernement du Canada
> -----Original Message-----
> From: Redman, Russell O. [mailto:[email protected]]
> Sent: Friday, 2003 July 04 3:38 PM
> To: Tech-Talk (E-mail)
> Cc: 'Honey, Allan'; Dunn, Jennifer; Wooff, Robert
> Subject: overheads in serial communications with drvAscii, sioSup &
> tnetDe v
> This is probably one for Allan Honey to consider, but may be of wider
> interest.
> I am experiencing very large overheads using serial
> communications to talk
> to a motor controller.  I am using drvAscii v2.2 with sioSup
> and tnetDev to
> communicate over a serial line to a motor controller.  The
> hardware layout
> is :
>    ioc --(Ethernet)-- terminal server --(19200)-- controller
> where I am using sioSup and tnetDev to connect to a specified
> port on a
> terminal server, which is configured to talk at 19200 baud to the
> controller.  The IOC an MVME2402-3, a PowerPC running VxWorks
> 5.4 and EPICS
> R3.13.5.
> I am passing short messages both ways across this link, 10
> characters max
> each way.  At 19200 baud, the line should pass about 2000
> characters each
> second, so the whole prompt/response sequence should be
> complete in about 10
> ms.  In fact, it takes around 300 to 400 ms to complete.
> Till now, I have
> operated on the assumption that the PPC was so fast that the
> latency in
> serial communications would be dominated by the baud rate,
> but apparently
> not.  After considerable testing, I am convinced that the
> controller is
> replying quite rapidly to each message and is not a
> significant source of
> delay.  I am convinced at the 95% level that the delay is introduced
> somewhere in the serial driver/Ethernet connection.
> For example, if I set a single record to scan every 0.1
> seconds, it is able
> to process once every 4 tries:
>   -> dbpf "conb:lo:gal:wrtst.TPRO","1"
>   DBR_UCHAR:          1         0x1
>   value = 0 = 0x0
>   -> dbpf "conb:lo:gal:wrtst.SCAN",".1 second"
>   DBR_STRING:          .1 second
>   value = 0 = 0x0
>   -> process:   conb:lo:gal:wrtst
>   active:    conb:lo:gal:wrtst
>   (etc...)
> An interesting variation is to forward link two records
>   conb:lo:gunn:x:rx.FLNK = conb:lo:gunn:x:px
>   -> dbpf "conb:lo:gunn:x:px.TPRO","1"
>   DBR_UCHAR:          1         0x1
>   value = 0 = 0x0
>   -> dbpf "conb:lo:gunn:x:rx.TPRO","1"
>   DBR_UCHAR:          1         0x1
>   value = 0 = 0x0
>   -> dbpf "conb:lo:gunn:x:rx.SCAN","Passive"
>   DBR_STRING:          Passive
>   value = 0 = 0x0
>   -> dbpf "conb:lo:gunn:x:rx.SCAN",".1 second"
>   value = 0 = 0x0
>   -> process:   conb:lo:gunn:x:rx
>   active:    conb:lo:gunn:x:rx
>   process:   conb:lo:gunn:x:px
>   process:   conb:lo:gunn:x:rx  - repeat block
>   active:    conb:lo:gunn:x:rx    |
>   process:   conb:lo:gunn:x:px  - end block
>   (etc...)
> In this case, rx is able to queue a message at the start of
> the block but
> must wait for both the previous px message and its own
> message to complete
> before it finishes processing and triggers px again.  The
> pair of messages
> take about 700 ms to complete.
> Needless to say, this overhead is unacceptably large.
> I have no idea where to begin looking for such large overheads in the
> drvAscii/sioSup/tnetDev combination, nor even whether this is the real
> source of the problem.  Any ideas what might be wrong?
> recherches Canada
Prev: overheads in serial communications with drvAscii, sioSup & tnetDe v Redman, Russell O.
Next: RE: EPICS collaboration meeting presentations Chestnut, Ronald P.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: StripTool Steven Hunt
