1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Linux and EPICS threads
To: "Eric Norum" <[email protected]>, "John Quintana" <[email protected]>
Cc: <[email protected]>
Date: Wed, 30 Jul 2003 14:23:30 -0500
> > The problem with ioperm is that you can only open up the first 0x3ff
> > ports.  After than you need to use iopl.
> But the original posting was about the parallel port wasn't
> it?  I was suggesting that ioperm would be a better choice for that
particular
> application.
I am writing to the parallel port (typically 4 addresses starting at
0x378), but I also need to write to the "ECR" register to select the EPP
mode of the parallel port.  That register is at 0x378 + 0x402, so I
don't know if ioperm() will work.  I'll try it out.
Prev: RE: Linux and EPICS threads John Quintana
Next: RE: Linux and EPICS threads Jun-ichi Odagiri
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: OMS VME58 card and user definable I/O Rok Sabjan
