1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: OMS VME58 card and user definable I/O
To: [email protected]
Date: Wed, 30 Jul 2003 13:05:07 +0200
Hello everyone,
I'm having small problems with the additional I/O signals on the OMS VME58 board. I'm using a debug routine that can send commands to the board and have some means of receiving them. I have also set the jumpers on the board to select bits 0-7 as outputs and 8-11 as inputs. Considering that RB command returns input/output configuration and BX returns the current value of the signal, I here state the whole testing results:
> "bx;"
< "\n\r0fff\n\r"
> "rb;"
< "\n\r30ff\n\r"
> "bh0;"
> "bx;"
< "\n\r0fff\n\r"
> "bx;"
< "\n\r0fff\n\r"
> "bl0;"
> "bx;"
< "\n\r0fff\n\r"
OMS58 Command ("q" to quit) >
As you can see, I get the correct response to the rb command. However, all bits are high all the time. I cannot change this with bl# and bh# commands. Has anyone got any suggestions? I would very much appreciate it..
Best regards,
Rok
Prev: Linux and EPICS threads Mark Rivers
Next: Re: Linux and EPICS threads Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Linux and EPICS threads Mark Rivers
Next: RE: Problem with static build on Linux Mark Rivers
