This wouldn't be the first time that glibc incompatabilites have come
up.
I've heard that the linux bbc distribution that normally compiles fine
under
Debian chokes miserably under Redhat 8.0.
- John
John Quintana 630-252-0221 (ph.)
Northwestern University 630-252-0226 (fax)
Building 432/A001 [email protected]
9700 S. Cass Ave
Argonne IL 60439
-----Original Message-----
Sent: Friday, August 01, 2003 11:31 AM
To: Mark Rivers
Cc: [email protected]
Subject: Re: Problem with static build on Linux
Mark Rivers wrote:
> This has now been reproduced on 3 separate Redhat 8 machines. Andrew
> Johnson built on a Redhat 9 machine, and the resulting static binary
> worked when run under both Redhat 9 and Redhat 8. It would be great
if
> some other folks could try this on Redhat 8 and 9 and see if it is
> actually a version problem. Any ideas why it does not work on Redhat
8
> would be most welcome.
Mark,
I'm now convinced this is a glibc problem - I rebuilt base on RH 8.0,
and
confirmed that I can reporduce your problem with a static build of the
example application. Then I rebuilt the example app on my RH 9.0
machine
but using the 8.0 build of base (this way around works, the reverse
doesn't). The only difference between the code in the result is the OS
libraries, which on RH 9.0 means glibc 2.3.2 vs 2.2.93. This binary
runs
quite happily on both OS versions.
I also managed to manually build a working executable on RH8.0 that
statically linked to the libraries from base but dynamically to the
system
libraries. The command line I used was this:
/usr/bin/g++ -o example
-L/home/phoebus/ANJ/epics/base/3-14-dev/lib/linux-x86/
-L/home/phoebus3/ANJ/apps/example-3.14/lib/linux-x86/
example_registerRecordDeviceDriver.o dbSubExample.o exampleMain.o
-Wl,-Bstatic -lxxxSupport -lrecIoc -lsoftDevIoc -ltestDevIoc -liocsh
-lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc
-ldbStaticIoc -lca -lCom -Wl,-Bdynamic -lpthread -lreadline -lncurses
-lm -lrt
Note the strategically placed -Wl,Bstatic and -Wl,-Bdynamic arguments.
I've filed a bug report to request the ability to build mixed-mode
binaries using this linker feature, but I don't know whether Janet would
be able to implement it in time for R3.14.3, probably not...
- Andrew
There are 10 types of people in the world:
Those who understand binary, and those who don't.
- Re: Problem with static build on Linux D. Peter Siddons
- Re: Problem with static build on Linux Andrew Johnson
RE: Problem with static build on Linux Mark Rivers
<2003>
2025
2026
<2003>
2025
2026
