Hello Juraj,
I have searched teck-talk and my own records and have
not been able to find any reports of similar problems.
Which model, and which firmware version, of the OMS
motor controller are you using (this is can be obtained
from the output of the "dbior" command at the VxWorks
shell)?
If you are using the motor record, which version of the
motor record (from the VERS field of the motor record)?
The least significant bit of the MSTA field in the motor record
can be used to determine the state of the direction signal (0:Negative,
1:Positive) in the OMS board. I suggest you monitor this bit
while jogging, and if the motor reverses direction while jogging
and the MSTA direction bit does not change state, then I agree
with Kay-Uwe that you may be exceeding speed or acceleration
limitations of the motor.
Let me know (off-line) if I can be of any help,
Ron Sluiter
Kay-Uwe Kasemir wrote:
At 08:40 8/7/2003, Juraj Krempasky wrote:
Dear all,
I observed something like a 'direction bit flip' when using the OMS motor card in JOG mode. The motor starts moving and then at full speed (!!!) reverts the direction. The limit switch it is now heading to is ignored, probably because it is believing to move in the opposite direction. Let me add, that the motor setup is a simple 0-360 deg rotation with 2 limit switches. One of the switches is used to set the motor counter to a certain value (motor initialization), so the motor counter never runs out of certain values between its limit switches.
Anybody observed similar behaviour, is the JOG mode somehow deprecated?
Can you confirm that the OMS board is really changing the direction bit
that's going to your driver/amplifier?
I have seen a motor change direction because e.g.
the JOG mode parameters (acceleration, speed) where configured
such that in JOG mode the pulses came out too fast for the motor
to follow. That can happen because the JOG mode parameters are separate
from the "normal" parameters.
The motor would then skip pulses or stop & restart in the opposite direction.
Not because it was _told_ to go into the opposite direction
but simply because the motor could not keep up with the incoming pulses.
Sort of like a digital scope that's undersampling a high-frequency signal
and then you see all sorts of strange effects.
-Kay
- RE: Problem with static build on Linux Mark Rivers
- Re: OMS motor card JOG mode problems Kay-Uwe Kasemir
Problems/questions with R3.14.2 example on win32-x86 Mark Rivers
<2003>
2025
2026
<2003>
2025
2026
