Folks,
I have built base-3.14.2 and seq-2.0.4 on win32-x86 (Windows XP, VC 6.0)
successfully. I have then built the example application that comes with
base. However, I have run into 2 problems in doing so.
1) If I build the example application dynamically (the default) then I
find that the application does not run unless all of the required dlls
are in my PATH environment variable. For example base/bin/win32-x86 and
seq/bin/win32-x86. This is not such a problem for the simple
application, but for real applications there will be over a dozen
applications that supply DLLs (mpf, std, motor, mca, etc.). It's a real
pain to have to put these in my PATH. Another problem with this is that
existing 3.13 extensions (for example ezcaIDL) require some DLLs
(ca.dll, com.dll) to be in the PATH, but the versions in the PATH now
are incompatible with the 3.14 versions, so this does not work.
Is this the correct and desired behavior? Is it possible to build
dynamically linked applications on Windows that have the paths to the
required DLLs built into the executable?
2) If I try to build the example application statically (setting
STATIC_BUILD=YES in example/configure/CONFIG then I get a fatal error in
linking:
link -nologo /incremental:no /opt:ref /release
-out:myexample.exe myexample_registerRecordDeviceDriver.obj
sncExample.obj myexampleMain.obj sncExample_sncreg.obj
J:/epics/3.14/example/lib/win32-x86/myexampleSupport.lib
h:/epics/seq-2.0.4/lib/win32-x86/seq.lib
h:/epics/seq-2.0.4/lib/win32-x86/pv.lib
h:/epics/base-3.14.2/lib/win32-x86/recIoc.lib
h:/epics/base-3.14.2/lib/win32-x86/softDevIoc.lib
h:/epics/base-3.14.2/lib/win32-x86/testDevIoc.lib
h:/epics/base-3.14.2/lib/win32-x86/iocsh.lib
h:/epics/base-3.14.2/lib/win32-x86/miscIoc.lib
h:/epics/base-3.14.2/lib/win32-x86/rsrvIoc.lib
h:/epics/base-3.14.2/lib/win32-x86/dbtoolsIoc.lib
h:/epics/base-3.14.2/lib/win32-x86/asIoc.lib
h:/epics/base-3.14.2/lib/win32-x86/dbIoc.lib
h:/epics/base-3.14.2/lib/win32-x86/registryIoc.lib
h:/epics/base-3.14.2/lib/win32-x86/dbStaticIoc.lib
h:/epics/base-3.14.2/lib/win32-x86/ca.lib
h:/epics/base-3.14.2/lib/win32-x86/Com.lib
ws2_32.libadvapi32.lib user32.lib kernel32.lib winmm.lib
myexample_registerRecordDeviceDriver.obj : error LNK2001: unresolved
external symbol _pxxxRecordSizeOffset
external symbol _pxxxRSET
external symbol _pwaveformRecordSizeOffset
external symbol _pwaveformRSET
external symbol _psubArrayRecordSizeOffset
external symbol _psubArrayRSET
external symbol _psubRecordSizeOffset
external symbol _psubRSET
external symbol _pstringoutRecordSizeOffset
external symbol _pstringoutRSET
external symbol _pstringinRecordSizeOffset
external symbol _pstringinRSET
external symbol _pstateRecordSizeOffset
external symbol _pstateRSET
external symbol _pseqRecordSizeOffset
external symbol _pseqRSET
external symbol _pselRecordSizeOffset
external symbol _pselRSET
external symbol _ppermissiveRecordSizeOffset
external symbol _ppermissiveRSET
external symbol _pmbboDirectRecordSizeOffset
external symbol _pmbboDirectRSET
external symbol _pmbboRecordSizeOffset
external symbol _pmbboRSET
external symbol _pmbbiDirectRecordSizeOffset
external symbol _pmbbiDirectRSET
external symbol _pmbbiRecordSizeOffset
external symbol _pmbbiRSET
external symbol _plongoutRecordSizeOffset
external symbol _plongoutRSET
external symbol _plonginRecordSizeOffset
external symbol _plonginRSET
external symbol _pfanoutRecordSizeOffset
external symbol _pfanoutRSET
external symbol _peventRecordSizeOffset
external symbol _peventRSET
external symbol _pdfanoutRecordSizeOffset
external symbol _pdfanoutRSET
external symbol _pcompressRecordSizeOffset
external symbol _pcompressRSET
external symbol _pcalcoutRecordSizeOffset
external symbol _pcalcoutRSET
external symbol _pcalcRecordSizeOffset
external symbol _pcalcRSET
external symbol _pboRecordSizeOffset
external symbol _pboRSET
external symbol _pbiRecordSizeOffset
external symbol _pbiRSET
external symbol _paoRecordSizeOffset
external symbol _paoRSET
external symbol _paiRecordSizeOffset
external symbol _paiRSET
external symbol _pdevXxxSoft
external symbol _pdevWfTestAsyn
external symbol _pdevWfSoft
external symbol _pdevSASoft
external symbol _pdevSoTestAsyn
external symbol _pdevSoSoft
external symbol _pdevSiTestAsyn
external symbol _pdevSiSoft
external symbol _pdevMbboDirectSoftRaw
external symbol _pdevMbboTestAsyn
external symbol _pdevMbboSoftRaw
external symbol _pdevMbbiDirectSoftRaw
external symbol _pdevMbbiTestAsyn
external symbol _pdevMbbiSoftRaw
external symbol _pdevLoSoft
external symbol _pdevLiSoft
external symbol _pdevEventTestIoEvent
external symbol _pdevEventSoft
external symbol _pdevBoTestAsyn
external symbol _pdevBoSoftRaw
external symbol _pdevBiTestAsyn
external symbol _pdevBiSoftRaw
external symbol _pdevAoTestAsyn
external symbol _pdevAoSoftRaw
external symbol _pdevAiTestAsyn
external symbol _pdevAiSoftRaw
external symbol _pmySub
external symbol _pasSub
external symbol _pdbbase
myexample.exe : fatal error LNK1120: 89 unresolved externals
gnumake[1]: *** [myexample.exe] Error 1120
rm sncExample_sncreg.obj sncExample_sncreg.cpp
gnumake[1]: Leaving directory
`J:/epics/3.14/example/myexampleApp/src/O.win32-x86'
gnumake: *** [install.win32-x86] Error 2
I don't understand these link errors, since most of these symbols should
be defined in recIoc.obj, which is being linked with.
Here is the output of dumpbin/exports on recIoc.obj
H:\epics\base-3.14.2\lib\win32-x86>dumpbin /exports recIoc.lib
Microsoft (R) COFF Binary File Dumper Version 6.00.8168
Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
Dump of file recIoc.lib
File Type: LIBRARY
Exports
ordinal name
_paaiRSET
_paaiRecordSizeOffset
_paaoRSET
_paaoRecordSizeOffset
_paiRSET
_paoRSET
_pbiRSET
_pboRSET
_pcalcRSET
_pcalcoutRSET
_pcompressRSET
_pdfanoutRSET
_pegRSET
_pegRecordSizeOffset
_pegeventRSET
_pegeventRecordSizeOffset
_perRSET
_perRecordSizeOffset
_pereventRSET
_pereventRecordSizeOffset
_peventRSET
_pfanoutRSET
_phistogramRSET
_phistogramRecordSizeOffset
_plonginRSET
_plongoutRSET
_pmbbiDirectRSET
_pmbbiRSET
_pmbboDirectRSET
_pmbboRSET
_ppermissiveRSET
_pselRSET
_pseqRSET
_pstateRSET
_pstringinRSET
_pstringoutRSET
_psubArrayRSET
_psubRSET
_pwaveformRSET
Summary
C3 .debug$S
14 .idata$2
14 .idata$3
4 .idata$4
4 .idata$5
C .idata$6
Any idea what is wrong?
Mark Rivers
Re: OMS motor card JOG mode problems Ronald L. Sluiter
building caTCL zhaozhuo
<2003>
2025
2026
compilering the crossgcc on RedHat linux9.0 zhaozhuo
<2003>
2025
2026
