Marty Kraimer wrote:
> Benjamin Franksen wrote:
> > Hmmm. It depends of course on how much is deemed "significant runtime
> > overhead". I imagine a solution along the following lines: All puts that
> > occur during asynch processing (i.e. target record's PACT==TRUE) are
> > redirected (by dbPut) into a queue (linked list or cicular buffer or
> > some such thing), where pairs consisting of {field address, new value}
> > are stored. Only when the record completes processing, the puts stored
> > in this list actally happen. After that eventual re-processing is done.
> > The advantage is that for the 'normal' situation (either PACT==FALSE or
> > dbScanLock is active) the only additional overhead is the check for PACT
> > and the check for an empty queue after processing. These are effectively
> > two machine instructions. Only if no scan lock is active and PACT==TRUE,
> > real overhead will occur. Even this overhead is not too great a cost,
> > IMHO, if it solves the problem.
> > I haven't spent any time thinking about the most clever representation
> > of the 'deferred puts' in the queue but certainly this can be worked
> > out.
> > What do you think?
> At the present time after initialization nothing in base except channel access
> server code allocates or frees memory. Channel access server code must because
> clients are connecting and disconnecting. The CA code manages memory VERY carefully.
> In order to implement what you suggest the queue must be managed very carefully.
Yes. Note that allocation and deallocation will happen in strict fifo
order. That's why I suggested a ring buffer. The buffer could be
allocated per record and only if such a put actually happens. IIRC, CA
does not deallocate its buffers and I'd suggest the same in this case
with the argument that such a condition (a put happens during asynch
processing) is likely to occur again in the future. Buffer size could be
increased if necessary.
BTW, isn't this is a good opportunity to leverage on the experience and
coding effort already sunk into CA? Maybe some of the CA code that
handles memory management can be factored out into an independent
library and then re-used?
> But what goes into the queue? What if the value is an array?
> If it is an array
> record support routines are involved. What fields of a record are involved?
The idea was to handle *all* (legal) puts to *any* field of the record.
Arrays, special fields etc. are handled exactly the same way as in the
normal case. The only difference is that the action is deferred until
processing of the target record is complete.
An interesting variant would be to allow record and device support to
flag those fields they are interested to protect and postpone puts only
to fields marked in this way. Yet another variant is to add this flag to
fields in the recordtype definition.
> Note
> that for the bo record only the VAL field is a problem because this is the only
> field that the bo record support compares with MLST.
Hmm. Doesn't this rather cure a symptom, instead of the cause? How long
until other problems surface? For instance, how many device supports
implicitly assume that the fields of a record don't change during
processing?
Of course, device supports and record supports *should* be aware of the
problem and save any record fields which are needed in the second stage
of asynch processing. But even if all of them did so, this is definitely
*not* efficient, since due to pessimistic assumtions copying must be
done each time, even if there will never be any put to any of the
relevant fields. With the scheme sketched above (copy-on-write), such
pessimistic copying can be abandoned.
Ben
- Re: Changes to records during asynch processing Marty Kraimer
- Does DISP work for DB OUT links? Benjamin Franksen
- Re: Does DISP work for DB OUT links? Marty Kraimer
- Re: Does DISP work for DB OUT links? Benjamin Franksen
- Re: Does DISP work for DB OUT links? Related question Benjamin Franksen
- Re: Does DISP work for DB OUT links? Related question Marty Kraimer
- Changes to records during asynch processing Benjamin Franksen
Re: [Fwd: Re: Does DISP work for DB OUT links? Related question] Marty Kraimer
Re: about NFS Billy R. Adams
<2003>
2025
2026
<2003>
2025
2026
