1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: about NFS
To: zhaozhuo <[email protected]>
Date: Fri, 29 Aug 2003 10:49:16 -0400
zhaozhuo,
    Redhat 9.0 has very tight security features.
Until you isolate the problem:
1. Try temporarily turn set security level to off.
2. Try temporarily removing /etc/hosts.allow and
   hosts.deny.
Then try:
3. Make sure that nfs is set to automatically start
   on bootup:  (you need nfslock as well as nfs)
   > chkconfig --list | grep nfs
   nfs             0:off   1:off   2:on    3:on    4:on    5:on    6:off
   nfslock         0:off   1:off   2:on    3:on    4:on    5:on    6:off
4. Make sure that portmap is set to automatically start
   on bootup:
    > chkconfig --list | grep portmap
    portmap         0:off   1:off   2:off   3:on    4:on    5:on    6:off
     Attached are my notes on NFS mounting.
Mounting NFS Files     July 25, 2003     [email protected]
Redhat Linux 9.0
Mounting NFS Files Errors:
Must have network connection:
  [root@bra-pc etc]# mount xcelsior:/home0 /mnt
  mount: RPC: Remote system error - No route to host
hostnames must be on the same network.
  [root@bra-pc etc]# mount xcelsior-2:/home0 /mnt
  mount: RPC: Timed out
  [root@bra-pc-20 root]# mount bra-pc-2:/home0 /mnt
  mount: RPC: Remote system error - Connection refused
  xcelsior ~/ > runas mount xcelsior:/home0 /mnt/floppy
  mount: xcelsior:/home0 failed, reason given by server: Permission denied
  xcelsior ~/ >
REQUIREMENTS for EXPORTING and MOUNTING FILE SYSTEMS
     NFS must be installed.
     hosts must be on the same network (No routing).
On host that is EXPORTING file system/s:
/etc/hosts.allow
        Example:
        portmap: 192.168.14.220, 192.168.14.221, 192.168.14.222: ALLOW
or
        No /etc/hosts.allow & No /etc/hosts.deny
Security Level
        High
        Customize
        Trusted Devices: eth0   (192.168.14.x) or Ethernet Port used.
or
        [No firewall]
On host that is MOUNTING file system/s:
Security Level
        High
        Customize
or
        [No firewall]
Billy
zhaozhuo wrote:
> hi,everyone!
> I want to share the directory "/export/home/zhaozhuo/medmtest" on the
> SUN Workstation/Solaris8 for a PC/Red Hat Linux9.
> SUN Workstation's name         aa (Server)
> PC's name                      bb (Client)
> So i do the following:
> 1.on aa
> share -F nfs -o ro=bb /export/home/zhaozhuo/medmtest
> 2.on bb
> mount -t nfs aa:/export/home/zhaozhuo/medmtest /home21
> but it shows the errors:
> mount:RPC:Timed out
> I've run the command "/etc/rc.d/init.d/nfs start" and I also checked the
> "nfsd" state by "ps -ed|grep nfsd.
> it shows the following:
> root       3285   1 0 Aug28 ?   00:00:00 [nfsd]
> root       3286   1 0 Aug28 ?   00:00:00 [nfsd]
> root       3287   1 0 Aug28 ?   00:00:00 [nfsd]
> root       3288   1 0 Aug28 ?   00:00:00 [nfsd]
> root       3289   1 0 Aug28 ?   00:00:00 [nfsd]
> root       3290   1 0 Aug28 ?   00:00:00 [nfsd]
> root       3291   1 0 Aug28 ?   00:00:00 [nfsd]
> root       3292   1 0 Aug28 ?   00:00:00 [nfsd]
> I don't know what's the reason,who can help me?
Billy Adams    <mailto:[email protected]>
                Raytheon Technical Services
  Assigned to:  Research Facilities Branch of
                Research Facilities Management Office
  16 Victory Street Mail Stop 413
  Building 1251, Room 126D
  NASA Langley Research Center
  Hampton, Va. 23681-2199
  Phone 1-757-864-6242     Fax   1-757-864-8095
about NFS zhaozhuo
Prev: Re: Changes to records during asynch processing Benjamin Franksen
Next: Home signal does not affect the .ATHM field of the motor record Rok Sabjan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: about NFS zhaozhuo
Next: Warning: message 19rjRN-0005cS-PQ delayed 48 hours Mail Delivery System
