1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Changes to records during asynch processing
To: Tim Mooney <[email protected]>
Cc: Marty Kraimer <[email protected]>, [email protected]
Date: Tue, 02 Sep 2003 11:56:04 -0600
Tim,
I concur with your fundamental idea and suggest that the .RPRO
field should contain a _list_ of structures to support
multiple writes from clients during the period when PACT==1.
The naive implementation is a simple FIFO queue for write requests,
although in general this should be a priority queue.
I think EPICS should never write to any record while PACT==1. (I'd like
to say that scanLock should persist through the I/O-wait period of asynchronous
processing, so that dbPutField could not modify any field in a lockset while
asynchronous processing was going on in that lockset, but I don't know enough
about the consequences of this.) Anyway, maybe .RPRO should be used not only
to signal that a record should be reprocessed, but also to cache the field name
and value that should be written. This would handle the problem of a
dbPutField to a record during asynchronous processing that was started by
a dbPutLink. It wouldn't necessarily handle the problem of a dbPutLink to
a record during asynchronous processing that was started by a dbPutField, because the record that caused the dbPutLink might have gone on to initiate
other processing sensitive to the field whose write has been postponed.
- Peregrine
Peregrine M. McGehee	[email protected]	(505) 667-3273
Sloan Digital Sky Survey / Spallation Neutron Source
MS H820, Los Alamos National Laboratory, Los Alamos, NM 87545
Re: Changes to records during asynch processing Andrew Johnson
Does DISP work for DB OUT links? Benjamin Franksen
Re: Does DISP work for DB OUT links? Marty Kraimer
Re: Does DISP work for DB OUT links? Benjamin Franksen
Re: Does DISP work for DB OUT links? Related question Benjamin Franksen
Re: Does DISP work for DB OUT links? Related question Marty Kraimer
Changes to records during asynch processing Benjamin Franksen
Re: Changes to records during asynch processing Marty Kraimer
Re: Changes to records during asynch processing Benjamin Franksen
Re: Changes to records during asynch processing Tim Mooney
Prev: Re: Changes to records during asynch processing Tim Mooney
Next: Re: Changes to records during asynch processing Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Changes to records during asynch processing Andrew Johnson
