1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem with seq 2.0.4
To: "Carl Lionberger" <[email protected]>, "Jeff Hill" <[email protected]>, "tech-talk" <[email protected]>
Date: Wed, 3 Sep 2003 08:25:46 -0500
Hi Carl,
> I've seen a similar problem with seq 2.0.2 when the ioc the
> sequencer was running on did not have ca security access to the PV's on the
> other ioc's it needed to connect to.  I think it miscounts the disconnects
> when it can't write to the PV's, probably adding a disconnect each time it
> fails.  In our situation, just giving write access to the PV's fixed it.  It
> looks to me like the sequencer does not implement the client-side api for
> channel access security.
I don't think that's our problem, because we have not implemented channel access security on any of our IOCs.  The PVs in the remote IOC are writeable, and in fact the previous version of the sequencer we were using (1.9.2beta12 from R3.13.7) was connecting to the PVs within a minute or so, after initial failures/disconnects.  Upgrading the IOC to 3.14.3 and seq-2.0.4 caused the disconnects to be permanent and fatal.
Prev: Re: [Fwd: Re: Does DISP work for DB OUT links? Related question] Marty Kraimer
Next: Re: [Fwd: Re: Does DISP work for DB OUT links? Related question] Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Problem with seq 2.0.4 Carl Lionberger
Next: RE: Problem with seq 2.0.4 Mark Rivers
