1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem with seq 2.0.4
To: Jeff Hill <[email protected]>, Mark Rivers <[email protected]>, tech-talk <[email protected]>
Date: Wed, 03 Sep 2003 01:51:40 -0400
I've seen a similar problem with seq 2.0.2 when the ioc the sequencer was
running on did not have ca security access to the PV's on the other ioc's it
needed to connect to.  I think it miscounts the disconnects when it can't
write to the PV's, probably adding a disconnect each time it fails.  In our
situation, just giving write access to the PV's fixed it.  It looks to me like
the sequencer does not implement the client-side api for channel access
security.
Carl
>===== Original Message From Mark Rivers <[email protected]> =====
>Jeff,
>> The database links are well tested in this mode of operation,
>> but perhaps there is a race condition in the sequencer which is influenced
by the
>> improved performance of CA in R3.14. There might also be a
>> problem in the R3.14 implementation of the CA client library.
>I am now quite convinced that the problem is CA related, and probably related
to the fact that 2 of the 26 PVs I am connecting 2 are in another IOC.  The
other 24 are local.  My other seq programs talk only to local PVs, and they
work fine.
>When the seq program fails to connect to some channels I see the following:
>seq &BM13_Energy, "E=13BMA:E, MONO=13BMA:m17, EXPTAB_Z=13BMD:m22,
YXTAL=13BMA:MON:, ZXTAL=13BMA:m14"
>@(#)SEQ Version 2.0.5: Tue Sep 2 15:52:2 2 CDT 20030x1238a08:
>Spawning state program "BM13_Energy", thread 0x11ae730: "BM13_Energy"
>value = 18540336 = 0x11ae730
>Done executing startup script /home/epics/3.14/CARS/iocBoot/ioc13bma/st.cmd
>ioc13bma> 24 of 26 assigned channels have connected
>DB CA Exception: "Virtual circuit disconnect", context "164.54.160.75:5064"
>CA.Client.Exception...............................................
>    Warning: "Virtual circuit disconnect"
>    Context: "164.54.160.95:5064"
>    Source File: ../cac.cpp line 1537
>    Current Time: TUE SEP 02 2003 20:18:09.811156578
>    Current Time: TUE SEP 02 2003 20:18:10.127823232
>    Current Time: TUE SEP 02 2003 20:18:13.461156432
>When the seq program initializes OK (which is rarely) I don't see these
CA.Client.Exception messages.  One puzzling thing is that the number of
unconnected channels reported by seq is not 2 (as it was in this particular
test, and as one might expect), but some integer times 2, so the number of
connected channels is 16, 18, 20, 22, 24 or 26.
>Is the above error message indicative of a problem with CA itself, or could
it be a problem with the seq client?
>The remote IOC is running EPICS 3.13.7.  It is healthy, lots of memory, no
CPU load, etc.  Here are the network related commands executed by the startup
script, in case I am doing something wrong:
># Set the default gateway
>routeAdd "0","164.54.160.1"
># The following line eliminates "cksum: out of data" messages due to DHCP
>proxyPortFwdOff(67)
># Define locations for logging and for APS EPICS process variables
>putenv("EPICS_IOC_LOG_INET=164.54.160.82")
>putenv("EPICS_CA_AUTO_ADDR_LIST=NO")
>putenv("EPICS_CA_ADDR_LIST=164.54.160.127")
>Note that even in EPICS 3.13 we have always had problems with PVs in remote
IOCs taking a long time (order of one minute) to connect to seq programs after
iocInit.  We also see similar error messages to those above, but the PVs
always eventually did connect.  In 3.14 they never connect.  Andrew Johnson
told me today that they are seeing similar things on 3.13.  I've been meaning
to report this/track it down for quite a while!
>Mark
Carl Lionberger
SNS Controls Group
(865) 574-7636
Prev: RE: Problem with seq 2.0.4 Mark Rivers
Next: Re: [Fwd: Re: Does DISP work for DB OUT links? Related question] Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Problem with seq 2.0.4 Mark Rivers
