One
possible way would be to construct a delay line of ai records, say delay0,
delay1 and delay2, and a calc record. Set their input
links
delay1.INP = delay0 NPP
delay2.INP = delay1 NPP
calc.INPA = delay0 NPP
calc.INPB = delay1 NPP
calc.INPC = delay2 NPP
and
their forward links
delay1.FLNK = delay0
delay2.FLNK = delay1
Processing starts with delay2 which gets its new value from the current
value of delay1, then causes delay1 to process. Delay1 gets its new value
from the current value of delay0, then causes delay0 to process. Delay0
gets its new value from the hardware, then causes the calc record to process and
compare the three values. Initializing the chain might be a bit of a
chore, however.
If you
need to do this in more than one place, this purely EPICS solution is not likely
to be the best solution. It is a bit more of a fuss to configure, but it
would probably be easier in the long run to write a few lines of C code to put
into a subr or gensub record.
Cheers,
Dr. Russell O. Redman Tel: (250) 363-6917 | Fax: (250)
363-0045 <mailto:[email protected]> National
Research Council Canada | Conseil national de recherches Canada 5071 West
Saanich Road | 5071
West Saanich Road Victoria, B. C. V9E
2E7 | Victoria, C.-B. V9E
2E7 Government of
Canada |
Gouvernement du Canada
Is there easy and natural way to monitor stale
data from, say, ai record just using EPICS records? For example, I have to
send alarm when several consecutive reading return the same value. The time
interval for those consecutive reading may be rather large, of the order of
minutes. If it would be shorter, I could use seq record with delays, but for
several minutes interval how can I trigger its processing?
Vladimir
