Another option for handling this is:
Modify the driver to keep a count of the number of times
the same value has been read. If the value is the same -
some number of times - when the database comes to read the
values - return an INVALID Status. It's a hardware failure
that is being recognized here and as such, it is the
responsibility of the driver. IMHO.
Bob
On Wed, 10 Sep 2003 13:58:59 -0700
"Redman, Russell O." <[email protected]>
wrote:
One possible way would be to construct a delay line of ai
records, say
delay0, delay1 and delay2, and a calc record. Set their
input links
delay0.INP = (hardware)
delay1.INP = delay0 NPP
delay2.INP = delay1 NPP
calc.INPA = delay0 NPP
calc.INPB = delay1 NPP
calc.INPC = delay2 NPP
and their forward links
delay0.FLNK = calc
delay1.FLNK = delay0
delay2.FLNK = delay1
Processing starts with delay2 which gets its new value
from the current
value of delay1, then causes delay1 to process. Delay1
gets its new value
from the current value of delay0, then causes delay0 to
process. Delay0
gets its new value from the hardware, then causes the
calc record to process
and compare the three values. Initializing the chain
might be a bit of a
chore, however.
If you need to do this in more than one place, this
purely EPICS solution is
not likely to be the best solution. It is a bit more of
a fuss to
configure, but it would probably be easier in the long
run to write a few
lines of C code to put into a subr or gensub record.
Cheers,
Dr. Russell O. Redman
Tel: (250) 363-6917 | Fax: (250) 363-0045
< mailto:[email protected]
<mailto:[email protected]> >
National Research Council Canada | Conseil national de
recherches Canada
5071 West Saanich Road | 5071 West Saanich Road
Victoria, B. C. V9E 2E7 | Victoria, C.-B. V9E
2E7
Government of Canada | Gouvernement du Canada
-----Original Message-----
From: Vladimir Sirotenko [mailto:[email protected]]
Sent: Wednesday, 2003 September 10 12:24 PM
To: [email protected]
Subject: stale data monitor
Is there easy and natural way to monitor stale data from,
say, ai record
just using EPICS records? For example, I have to send
alarm when several
consecutive reading return the same value. The time
interval for those
consecutive reading may be rather large, of the order of
minutes. If it
would be shorter, I could use seq record with delays, but
for several
minutes interval how can I trigger its processing?
Vladimir
Bob Dalesio
[email protected]
410 557 0297 Maryland
505 667 3414 Los Alamos
505 699 1632 Cell Phone
505 667 6087 Our Secretary (Lisa Marie)
- RE: stale data monitor Redman, Russell O.
Re: Epics / OS-X Eric Norum
Motor record bug report Rok . Sabjan
<2003>
2025
2026
Epics / OS-X Matthieu Bec
<2003>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
