But base3.14.2 and base3.14.3 versions test_registerRecordDeviceDriver(pdbbase) functions loding errors. Were there any error messages from [gnu]make when you built this application? test_registerRecordDeviceDriver(pdbbase) The above stack trace shows that the processor is trying to execute instructions from address 0x20, which cannot be the correct address for the sizeOffset routine of any record type. This is probably an unresolved reference. The probeem from this functions. sizeOffset(dbEntry.precordType); You should try doing a "make rebuild" (or "gnumake rebuild") from the top of your application - I suspect it didn't link properly. If the build fails or prints any warning or error messages you need to investigate and fix those. If that doesn't solve it, did you have any problems building base at all? Was this test application created by R3.14.3, or by a different release of Base? - Andrew -- There are 10 types of people in the world: Those who understand binary, and those who don't.
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
