Dear Andrew,
Thanks for your prompt reply for my problem.
> Were there any error messages from [gnu]make when you built this application?
The base and application compile was just clearly completed. This problem was iocCore loading after record registration problem.
I tried many times recompile and excutions the base3.14.2 and base3.14.3 example IOCs.
At the Windows2K and linux OS the base3.13.2 with base3.13.3 working well for my applications.
> You should try doing a "make rebuild" (or "gnumake rebuild") from the top
> of your application - I suspect it didn't link properly. If the build
> fails or prints any warning or error messages you need to investigate and
> fix those. If that doesn't solve it, did you have any problems building
> base at all?
The base program and any application compiles clean without error message.
But the same target environment the base3.14.1.cvs version was woking well.
>Was this test application created by R3.14.3, or by a
> different release of Base?
I'm sure, application created at the same release.
My Host environment :
-Windows2K
-Tornado2.2 (vxWorks5.5.1)
-used base : base3.13.7, base3.13.8
base3.14.1.cvs
Best regards,
Kiman Ha,
PLS Control group
> -----Original message-----
> From: "AndrewJohnson" <[email protected]>
> To: "KimanHa" <[email protected]>
> Cc: [email protected]
> Date: 09/13/2003(Sat)04:10
> Subject: Re: epics ioc3.14.3 problem at the tornado2.2
> Kiman Ha wrote:
> > But base3.14.2 and base3.14.3 versions
> > test_registerRecordDeviceDriver(pdbbase) functions loding errors.
> > alignment
> > Exception current instruction address: 0x00000020
> > Machine Status Register: 0x0200b030
> > Data Access Register: 0x073b509b
> > Condition Register: 0x20002044
> > Data storage interrupt Register: 0x00005fff
> > 24aa24 vxTaskEntry +68 : shell ()
> > 2017ec shell +190: 201818 ()
> > 201a18 shell +3bc: execute ()
> > 201b54 execute +90 : 201818 ()
> > 201b9c execute +d8 : yyparse ()
> > 21fd10 yyparse +71c: 21e0a8 ()
> > 21e22c yystart +96c: test_registerRecordDeviceDriver ()
> > 72b0e34 test_registerRecordDeviceDriver+12c: 20 ()
> The above stack trace shows that the processor is trying to execute
> instructions from address 0x20, which cannot be the correct address for
> the sizeOffset routine of any record type. This is probably an unresolved
> reference.
> > The probeem from this functions. sizeOffset(dbEntry.precordType);
> base at all? Was this test application created by R3.14.3, or by a
> - Andrew
> There are 10 types of people in the world:
> Those who understand binary, and those who don't.
Re: epics ioc3.14.3 problem at the tornado2.2 Andrew Johnson
Problems using Epics R3.14.3 with mvme5110 PowerPc Dennis Armstrong
<2003>
2025
2026
<2003>
2025
2026
