Dennis Armstrong
I had a same experience at the MVME5110 with Tornado 2.2 .
That time jeff helped for fixing that problem.
What kind tornado version used?
When the making the vxworks Kernel, If you added (remote route protocol? component) that component with epics CA making problem.
at the your task list you can not found "CAS-UDP" tasks. "CAS-UDP" task for CA client.
I'm sorry I'm visiting at SLAC ESD group, my problem note leave at PLS in KOREA.
This problem was same as last year when the starting Tornado2.2 with MVME51xx SBC.
NAME ENTRY TID PRI total % (ticks) delta % (ticks)
tExcTask excTask 1efe5290 0 0% ( 0) 0% ( 0)
tLogTask logTask 1efe26f0 0 0% ( 0) 0% ( 0)
tShell shell 1eee7460 1 0% ( 0) 0% ( 0)
tRlogind rlogind 1eef7b50 2 0% ( 0) 0% ( 0)
tWdbTask wdbTask 1eeefe30 3 0% ( 0) 0% ( 0)
tAioIoTask1 aioIoTask 1eff43b0 50 0% ( 0) 0% ( 0)
tAioIoTask0 aioIoTask 1efed130 50 0% ( 0) 0% ( 0)
tNetTask netTask 1efa41a0 50 0% ( 1) 0% ( 1)
tAioWait aioWaitTas 1effb630 51 0% ( 0) 0% ( 0)
tPortmapd portmapd 1eefaf40 54 0% ( 0) 0% ( 0)
tTelnetd telnetd 1eef57a0 55 0% ( 0) 0% ( 0)
tRipTimerTas ripTimer 1eee86a0 100 0% ( 0) 0% ( 0)
tRipTask ripTask 1eef21f0 101 97% ( 1551) 97% ( 1551)
syncNTP 1eb41ed0 109 0% ( 0) 0% ( 0)
cbHigh 1eb23c90 128 0% ( 0) 0% ( 0)
timerQueue 1ef019e0 129 0% ( 0) 0% ( 0)
scanOnce 1eb18c70 129 0% ( 0) 0% ( 0)
scan0.1 1eaf2400 133 0% ( 0) 0% ( 0)
scan0.2 1eaf7c10 134 0% ( 0) 0% ( 0)
cbMedium 1eb294a0 135 0% ( 0) 0% ( 0)
scan0.5 1eafd420 135 0% ( 0) 0% ( 0)
scan1 1eb02c30 136 0% ( 0) 0% ( 0)
scan2 1eb08440 137 0% ( 0) 0% ( 0)
scan5 1eb0dc50 138 0% ( 0) 0% ( 0)
scan10 1eb13460 139 0% ( 0) 0% ( 0)
cbLow 1eb3d3b0 140 0% ( 0) 0% ( 0)
dbCaLink 1eb1e480 149 0% ( 0) 0% ( 0)
CAS-TCP 1eaecbf0 181 0% ( 0) 0% ( 0)
---------------------------------------------------------------------------**** CAS-UDP task need for extension CA client----------------------------------------------------------------------------errlog 1ee40aa0 189 0% ( 0) 0% ( 0)
errlog 1eea5c10 189 0% ( 0) 0% ( 0)
errlog 1ea1d2b0 189 0% ( 0) 0% ( 0)
taskwd 1fffef50 189 0% ( 0) 0% ( 0)
KERNEL 2% ( 35) 2% ( 35)
INTERRUPT 0% ( 0) 0% ( 0)
IDLE 0% ( 0) 0% ( 0)
TOTAL 99% ( 1587) 99% ( 1587)
Kiman Ha,
PLS Control Group.
Hi all
I am having trouble connecting to our new PowerPc card using EPICS r3.14.3.
I have built EPICS base and some of the extensions.
I can boot the ioc with an epics database (the demo.db one fron the sequencer extension)
I can access the datebase when logged into the ioc from a console ie dbpf, dbgf and dbl commands all work
and I can access the various pv fields.
I cannot access the database from outside the ioc using caget or medm. caget returns an "Invalid channel name" when
accessing any of the PowerPC PV's although it is quite happy to access the other iocs running EPICS R3.13.1
I tried to telnet to port 5064 on the ioc but it reports connection refused. It looks like the ioc isn't listening on this port.
The only tcp ports it recognises are 23, 111 and 513
Any suggestions as to whats missing in the ioc?
regards
Dennis Armstrong
Re: aps cvs access Andrew Johnson
Re: Problems using Epics R3.14.3 with mvme5110 PowerPc Dennis Armstrong
<2003>
2025
2026
<2003>
2025
2026
