1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Homing speed
To: Rok Sabjan <[email protected]>
Cc: [email protected]
Date: Thu, 18 Sep 2003 12:27:20 -0500
A home velocity field (HVEL) was added to the motor record with release R4.7;
you can obtain a copy of it at the following web page,
http://www.aps.anl.gov/upd/people/sluiter/epics/motor/index.html
Rok Sabjan wrote:
Hi folks!
I have some problems on some devices with default EPICS motor record home speed (1000 steps/second) - too high. Since this seems to be hardcoded, I am tempted by the following suggestions:
- home speed is configurable (I know that OMS card supports that option)
- I rebuild the motor record for the concrete motors and change the default value. In this case I have to know where this is coded.
Other suggestions from community regarding this issue will be welcome. I cannot write my own database doing it manually, as I in some cases have to refer to encoder reference position and not the home switch.
Thanx!
regards,
Rok
Homing speed Rok Sabjan
Prev: Homing speed Rok Sabjan
Next: Subnet-based env settings on unix Susanna Jacobson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
