1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA block sem corrupted error and S_errno_ENOBUFS
To: "'Jeff Hill'" <[email protected]>
Cc: EPICS-tech-talk <[email protected]>
Date: Mon, 20 Oct 2003 09:24:25 -1000
Thank you all for the responses...
Assuming that we've been running this same software
for sometime... could hardware failures cause these
symptoms, i.e. cards going bad, flaky power supply?
Also what version of VxWorks would you recommend
running with R3.13.9?
Thanks again.
Kevin
-----Original Message-----
Sent: Monday, October 20, 2003 8:00 AM
To: Kevin Tsubota
Cc: EPICS-tech-talk
> Does anyone know what would be causing a: CA block sem corrupted error?
I see that the very latest version of R3.13 does have the warning message
"CAC block sem corrupted" which is nearly identical to the one that you are
reporting. The message occurs when the vxWorks semGive() function returns an
error. My best guess is that some agent is corrupting the client library's
data structures.
> We've also noticed we're getting a BFL (board failure) indicator on
Perhaps the board fail status may be occurring because of an exception at
interrupt level (sometimes because the interrupt dispatch table has been
corrupted).
> Also we've also experienced: CAS: TCP send to "host" failed because
> "S_errno_ENOBUFS"
The generally accepted solution is to add more mbufs, and this seems to have
been sufficient at many sites, but you should know that mbuf starvation
issues are occurring more frequently at the SNS lately and therefore are
receiving heightened attention.
A fix was made in R3.13.9 to make the software more robust in low mbuf
situations, but this was fixing a rarely occurring bug with different
symptoms than what you are reporting.
> We're still running EPICS R3.13.0beta12
Many patches have been applied to R3.13 since this release.
Jeff
> From: Kevin Tsubota [mailto:[email protected]]
> Sent: Saturday, October 18, 2003 5:41 PM
> To: tech-talk (E-mail)
> Subject: CA block sem corrupted error and S_errno_ENOBUFS
> Hi,
> We're still running EPICS R3.13.0beta12 on MV2304s with VxWorks 5.3.1.
> We've also noticed we're getting a BFL (board failure) indicator on our
> MVME2304s.
> Could these be related?
> Can someone point me to documenation where I can find out more about
> these
> board failures?
> "S_errno_ENOBUFS"
> errors.  I believe this is a VxWorks resource issue but don't know which
> resource.  Which
> VxWorks resource do I need to increase?
> Thank you in advance.
> Kevin Tsubota
> W.M. Keck Observatory
> (808)885-7887
Re: CA block sem corrupted error and S_errno_ENOBUFS Andrew Johnson
Prev: RE: CA block sem corrupted error and S_errno_ENOBUFS Jeff Hill
Next: Encoders Robert Henning
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: CA block sem corrupted error and S_errno_ENOBUFS Andrew Johnson
