1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: a question about rup in sad
To: Zhao Zhuo <[email protected]>
Cc: [email protected], Kazuro FURUKAWA <[email protected]>
Date: Sun, 09 Nov 2003 00:01:10 +0900
Hi Zhuo,
>>> On Fri, 07 Nov 2003 19:50:42 JST,  Zhao Zhuo <[email protected]> wrote;
> I perform sad programe in the redhat linux9,but it shows some error about
> "rup",because i have no rup in my system,so who can tell me what is
> "rup" and how i can install the "rup"?
> thanks a lot.
I think you refer to "rup" which is used in kekb-launcher (kbl).  If
so, it expects non-standard option "-s" (search time), which is
supported in my implementation of "rup".  On finding load averages,
some of the target machines may be down and we had to wait long time
for rup to time-out.  We found my "-s" option cures such situation,
although it is not optimal.
You may find the source code at
  <URL:http://www-linac.kek.jp/cont/src/rup-5.5.3.tar.gz>
"make rup" will build it.
usage: rup [-{t|l|h}r] [-n] [-sNN] [hosts ...]
  -t: sort by uptime,  -l: by load, -h: by hostname,  -r: reverse
  -n: numerical address (only with sort options),     -v: verbose
  -s NN: search time in NN seconds (default is 60)
By the way, rup server (rstatd) is not enabled on redhat linux by
default, and you need to enable it in rc?.d/S??rstatd.
Cheers, Kazuro.
 Linac,  High Energy Accelerator Research Organization (KEK), Japan
a question about rup in sad Zhao Zhuo
Prev: Re: configure/RELEASE contents Andrew Johnson
Next: Re: configure/RELEASE contents Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: a question about rup in sad Zhao Zhuo
Next: configure/RELEASE contents Geoff Savage
