1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: configure/RELEASE contents
To: [email protected]
Date: Sun, 9 Nov 2003 01:22:57 +0100
On Saturday 08 November 2003 01:55, Andrew Johnson wrote:
> Don't use environment variables.  Your configure/RELEASE file can contain
> include statements, so can pull in settings from files elsewhere.  I
> suggest that if you don't like having to set up all your pointers to the
> 'right' versions in every application, that you have another file
> containing SUPPORT=/path/to/something
> 	EPICS_DIR=/path/to/base
> 	SYMB=$(SUPPORT)/symb
> 	VXSTATS=$(SUPPORT)/vxStats
Hi Andrew
Including other makefiles doesn't work because convertRelease.pl just looks at
definitions (of the form NAME=VALUE), not at everything (gnu-)make
understands (include, etc...).
(I agree that using environment variables is not such a good idea.)
Ben
Re: configure/RELEASE contents Andrew Johnson
configure/RELEASE contents Geoff Savage
Prev: Re: a question about rup in sad Kazuro FURUKAWA
Next: EPICS training Bob Dalesio
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: configure/RELEASE contents Andrew Johnson
Next: Re: configure/RELEASE contents Andrew Johnson
