Aloha,
In the recent past the TCS IOC for CFHT switched EPICS
versions from 3.13.6 to 3.13.8. A CA client on an HPUX
host (which remained under 3.13.6) started crashing
with a core dump not much later. Running purify against
the client yielded several BSR (Beyond stack read errors)
from */epics/base/src/ca/access.c/iocinf.c
I compiled the client against 3.13.8 libraries and the
BSR error disappears. This is good, however it is of
concern that an issue of compatibility between the versions
may be in question?
Here are a few preliminary results from purify (more running
time needed of course for 'core' error to occur)
Thoughts?
regards & thx,
rosemary.
Client compiled with 3.13.8 libs - purify log - no errors
(see further below for client compiled with 3.13.6 libs & BSR errors)
**** Purify instrumented /cfht/obs/tcs/tcs-pure (pid 2384 at Fri Nov 7 11:35:33 2003)
* Purify 5.1-proto-H2 991020 HP-UX, Copyright (C) 1992-1999 Rational Software Corp. All rights reserved.
* For contact information type: "purify -help"
* Command-line: /cfht/obs/tcs/tcs-pure
* Options settings: -purify \
-log-file=/cfht/src/medusa/tcs/tcs/tcs_purify.log \
-purify-home=/apps/pure/purify-hpux
* Purify licensed to Canada-France-Hawaii Telescop or Purify Evaluation User
* Purify checking enabled.
**** Purify instrumented /cfht/obs/tcs/tcs-pure (pid 2384) ****
Current file descriptors in use: 9
FIU: file descriptor 0: <stdin>
FIU: file descriptor 1: <stdout>
FIU: file descriptor 2: <stderr>
FIU: file descriptor 3: <unnamed socket>, O_RDWR
* This file descriptor was allocated from:
_socket_sys [libc.1]
socket [libc.1]
create_net_chan [libca.a]
cac_create_udp_fd [libca.a]
ca_search_and_connect [libca.a]
monitor [tcs_agent_monitor.c:577]
FIU: file descriptor 4: <unnamed socket>, O_RDWR
socket [libc.1]
clntudp_bufcreate [libc.1]
yp_get_default_domain [libc.1]
_yp_flock [libc.1]
_yp_dobind [libc.1]
FIU: file descriptor 5: <unnamed socket>, O_RDWR
socket [libc.1]
alloc_ioc [libca.a]
perform_claim_channel [libca.a]
post_msg [libca.a]
FIU: file descriptor 6: <stderr>
* Duplication of file descriptor 2.
_dup_sys [libc.1]
dup [libc.1]
SetUpLogging [cfht_log.c:411]
LogIt [cfht_log.c:734]
cfht_log [cfht_log.c:1046]
tcsInit [tcss_misc.c:655]
FIU: file descriptor 26: <reserved for Purify internal use>
FIU: file descriptor 27: <reserved for Purify internal use>
Purify: Searching for all memory leaks...
Memory leaked: 0 bytes (0%); potentially leaked: 0 bytes (0%)
Purify Heap Analysis (combining suppressed and unsuppressed blocks)
Blocks Bytes
Leaked 0 0
Potentially Leaked 0 0
In-Use 212 167100
Total Allocated 212 167100
* Program exited with status code 0.
* 0 access errors, 0 total occurrences.
* 0 bytes leaked.
* 0 bytes potentially leaked.
* Basic memory usage (including Purify overhead):
699488 code
177016 data/bss
244872 heap (peak use)
592 stack
* Shared library memory usage (including Purify overhead):
156608 dld_pure_p3_c0_110202215_B1020_114688.sl (shared code)
9664 dld_pure_p3_c0_110202215_B1020_114688.sl (private data)
159744 libm.1_pure_p3_c0_110202215_B1020_135168 (shared code)
20480 libm.1_pure_p3_c0_110202215_B1020_135168 (private data)
3289088 libc.1_pure_p3_c0_110202215_B1020_1863680 (shared code)
184320 libc.1_pure_p3_c0_110202215_B1020_1863680 (private data)
8192 libdld.1_pure_p3_c0_110202215_B1020_12288 (shared code)
4096 libdld.1_pure_p3_c0_110202215_B1020_12288 (private data)
End
BSR errors
Client Compiled with 3.13.6 libs, running against server
(IOC) is 3.13.8. Purify log
**** Purify instrumented /cfht/obs/tcs/tcs-pure (pid 24182 at Thu Nov 6 14:55:10 2003)
**** Purify instrumented /cfht/obs/tcs/tcs-pure (pid 24182) ****
BSR: Beyond stack read error:
* This is occurring while in:
cac_mux_io [iocinf.c:2132]
cac_block_for_io_completion [posix_depen.c:97]
ca_pend [access.c:2940]
monitor [tcs_agent_monitor.c:583]
main [tcs_agent.c:107]
_start [libc.1]
* Reading 8 bytes from 0x7b03b0a0.
* Stack pointer 0x7b03b080
* Address 0x7b03b0a0 is 24 bytes past start of local variable "timeout" in function cac_mux_io.
cac_push_msg [access.c:544]
issue_identify_client [access.c:3447]
perform_claim_channel [service.c:946]
cacMsgUDP [service.c:712]
post_msg [service.c:233]
ca_process_udp [iocinf.c:1392]
* Reading 8 bytes from 0x7b03b608.
* Stack pointer 0x7b03b5c0
* Address 0x7b03b608 is 48 bytes past start of local variable "itimeout" in function cac_push_msg.
issue_client_host_name [access.c:3402]
perform_claim_channel [service.c:947]
ca_flush_io [access.c:3090]
cac_reconnect_channel [service.c:1127]
cacMsgTCP [service.c:680]
post_msg [service.c:236]
ca_process_tcp [iocinf.c:1229]
* Reading 8 bytes from 0x7b03b760.
* Stack pointer 0x7b03b740
* Address 0x7b03b760 is 24 bytes past start of local variable "timeout" in function cac_mux_io.
ca_request_event [access.c:2375]
ca_add_masked_array_event [access.c:2305]
connect_handler1 [tcs_agent_monitor.c:909]
* Reading 8 bytes from 0x7b03b888.
* Stack pointer 0x7b03b840
* Address 0x7b03b888 is 48 bytes past start of local variable "itimeout" in function cac_push_msg.
ca_add_masked_array_event [access.c:2319]
* Reading 8 bytes from 0x7b03b6f8.
* Stack pointer 0x7b03b6c0
* Address 0x7b03b6f8 is 56 bytes above frame pointer in function ca_add_masked_array_event.
ca_pend [access.c:2947]
connect_handler1 [tcs_agent_monitor.c:919]
* Reading 8 bytes from 0x7b03b6f0.
* Address 0x7b03b6f0 is 32 bytes past start of local variable "tmo" in function ca_pend.
ca_pend [access.c:2935]
_start [libc.1]
_start [libc.1]
$START$ [crt0.o]
* Reading 8 bytes from 0x7b03af70.
* Stack pointer 0x7b03af40
* Address 0x7b03af70 is 32 bytes past start of local variable "tmo" in function ca_pend.
mark_server_available [conn.c:685]
cacMsgUDP [service.c:744]
ca_process_input_queue [iocinf.c:1105]
cac_mux_io [iocinf.c:2127]
* Reading 8 bytes from 0x7b03b448.
* Stack pointer 0x7b03b400
* Address 0x7b03b448 is 32 bytes past start of local variable "next" in function mark_server_available.
tcs_connect [tcs_agent_monitor.c:637]
monitor [tcs_agent_monitor.c:598]
* Reading 8 bytes from 0x7b03b120.
* Stack pointer 0x7b03b100
* Address 0x7b03b120 is 24 bytes past start of local variable "timeout" in function cac_mux_io.
connect_handler [tcs_agent_monitor.c:696]
* Reading 8 bytes from 0x7b03b908.
* Stack pointer 0x7b03b8c0
* Address 0x7b03b908 is 48 bytes past start of local variable "itimeout" in function cac_push_msg.
* Reading 8 bytes from 0x7b03b778.
* Address 0x7b03b778 is 56 bytes above frame pointer in function ca_add_masked_array_event.
connect_handler [tcs_agent_monitor.c:706]
* Reading 8 bytes from 0x7b03b770.
* Address 0x7b03b770 is 32 bytes past start of local variable "tmo" in function ca_pend.
_start [libc.1]
$START$ [crt0.o]
* Reading 8 bytes from 0x7b03aff0.
* Stack pointer 0x7b03afc0
* Address 0x7b03aff0 is 32 bytes past start of local variable "tmo" in function ca_pend.
tcs_connect [tcs_agent_monitor.c:652]
_start [libc.1]
$START$ [crt0.o]
monitor [tcs_agent_monitor.c:601]
_start [libc.1]
$START$ [crt0.o]
_start [libc.1]
$START$ [crt0.o]
monitor [tcs_agent_monitor.c:602]
_start [libc.1]
$START$ [crt0.o]
_start [libc.1]
$START$ [crt0.o]
monitor [tcs_agent_monitor.c:605]
_start [libc.1]
$START$ [crt0.o]
_start [libc.1]
$START$ [crt0.o]
monitor [tcs_agent_monitor.c:606]
_start [libc.1]
$START$ [crt0.o]
_start [libc.1]
$START$ [crt0.o]
monitor [tcs_agent_monitor.c:607]
_start [libc.1]
$START$ [crt0.o]
tcsEPICSWait [tcss_misc.c:1025]
tcsSendToTCS [tcss_misc.c:3232]
send_to_tcs [tcs_agent_com.c:203]
* Reading 8 bytes from 0x7b03b920.
* Stack pointer 0x7b03b900
* Address 0x7b03b920 is 24 bytes past start of local variable "timeout" in function cac_mux_io.
ca_pend [access.c:2886]
com_tcoords [tcs_agent_com.c:599]
* Reading 8 bytes from 0x7b03b8a0.
* Stack pointer 0x7b03b880
* Address 0x7b03b8a0 is 24 bytes past start of local variable "timeout" in function cac_mux_io.
cli_execute [cli_comlist.c:429]
* Reading 8 bytes from 0x7b03b7f0.
* Stack pointer 0x7b03b7c0
* Address 0x7b03b7f0 is 32 bytes past start of local variable "tmo" in function ca_pend.
com_ocoords [tcs_agent_com.c:1331]
* Reading 8 bytes from 0x7b03b6a0.
* Stack pointer 0x7b03b680
* Address 0x7b03b6a0 is 24 bytes past start of local variable "timeout" in function cac_mux_io.
* Reading 8 bytes from 0x7b03b5f0.
* Address 0x7b03b5f0 is 32 bytes past start of local variable "tmo" in function ca_pend.
cac_reconnect_channel [service.c:1104]
* Reading 8 bytes from 0x7b03bac8.
* Stack pointer 0x7b03ba80
* Address 0x7b03bac8 is 48 bytes past start of local variable "itimeout" in function cac_push_msg.
com_gcoords [tcs_agent_com.c:1096]
* Reading 8 bytes from 0x7b03b720.
* Stack pointer 0x7b03b700
* Address 0x7b03b720 is 24 bytes past start of local variable "timeout" in function cac_mux_io.
* Reading 8 bytes from 0x7b03b670.
* Stack pointer 0x7b03b640
* Address 0x7b03b670 is 32 bytes past start of local variable "tmo" in function ca_pend.
com_gcoords [tcs_agent_com.c:1103]
socket [libc.1]
create_net_chan [iocinf.c:451]
cac_create_udp_fd [access.c:826]
ca_search_and_connect [access.c:1154]
socket [libc.1]
_yp_flock [libc.1]
_yp_dobind [libc.1]
socket [libc.1]
create_net_chan [iocinf.c:300]
alloc_ioc [iocinf.c:221]
perform_claim_channel [service.c:911]
_dup_sys [libc.1]
dup [libc.1]
Blocks Bytes
Leaked 0 0
In-Use 220 168030
Total Allocated 220 168030
* 128 access errors, 1655 total occurrences.
* 0 bytes leaked.
701312 code
176952 data/bss
244936 heap (peak use)
592 stack
RE: Among the things for which I wish... Jeff Hill
Re: Help about building a example under cygwin Eric Norum
<2003>
2025
2026
RE: EPICS periodic scan and sysClkRateSet() Kevin Tsubota
CAEN V560 interchangeable with CAEN V260? Dayle Kotturi
<2003>
2025
2026
