1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Help about building a example under cygwin
To: guobao shen <[email protected]>
Date: Fri, 14 Nov 2003 15:45:23 -0600
guobao shen wrote:
Hello, everyone,
I have succeeded in building EPICS 3.14.4 base under Cygwin, windows 2000, but there is a problem when I
built  an example. My steps are:
 1. perl makeBaseApp.pl -t example example
 2. perl makeBaseApp.pl -i -t example example
 3. make
You need to give the full path to the perl script. Here's the output I obtained from building the example application on cygwin. No problems with building or running (well, link-edits are slooooow, but that may have more to do with our NFS setup than anything else).
BTW -- I've successfully built and run a cygwin IOC performing I/O to GPIB and serial devices using the soon-to-be-released asynDriver, devGpib and drvGenericSerial support.
Eric Norum                                 [email protected]
Advanced Photon Source                     Phone: (630) 252-4793
Argonne National Laboratory
Norume@CTLPC20 ~/src/chk/epics
$ mkdir wex
$ cd wex
Norume@CTLPC20 ~/src/chk/epics/wex
$ ~/src/EPICS/base_R3_14_2_branch/bin/win32-x86-cygwin/makeBaseApp.pl -t exampl
e myExample
$ ~/src/EPICS/base_R3_14_2_branch/bin/win32-x86-cygwin/makeBaseApp.pl -i -t exa
mple myExample
The following target architectures are available in base:
    linux-x86
    solaris-sparc
    darwin-ppc
    vxWorks-ppc604
    vxWorks-ppc603
    vxWorks-68040
    win32-x86-cygwin
    RTEMS-pc386
What architecture do you want to use? win32-x86-cygwin
$ make
make -C configure install
make[1]: Entering directory `/cygdrive/p/src/chk/epics/wex/configure'
perl /home/phoebus/NORUME/src/EPICS/base_R3_14_2_branch/configure/tools/convertR
elease.pl -h win32-x86-cygwin checkRelease
perl /home/phoebus/NORUME/src/EPICS/base_R3_14_2_branch/configure/tools/makeMake
file.pl O.win32-x86-cygwin ../..
mkdir O.Common
make -C O.win32-x86-cygwin -f ../Makefile TOP=../.. T_A=win32-x86-cygwin install
make[2]: Entering directory `/cygdrive/p/src/chk/epics/wex/configure/O.win32-x86
-cygwin'
elease.pl -h win32-x86-cygwin CONFIG_APP_INCLUDE
elease.pl -h win32-x86-cygwin RULES_INCLUDE
make[2]: Leaving directory `/cygdrive/p/src/chk/epics/wex/configure/O.win32-x86-
cygwin'
make[1]: Leaving directory `/cygdrive/p/src/chk/epics/wex/configure'
make -C myExampleApp install
make[1]: Entering directory `/cygdrive/p/src/chk/epics/wex/myExampleApp'
make -C src install
make[2]: Entering directory `/cygdrive/p/src/chk/epics/wex/myExampleApp/src'
file.pl O.win32-x86-cygwin ../../..
mkdir O.Common
make -C O.win32-x86-cygwin -f ../Makefile TOP=../../.. T_A=win32-x86-cygwin inst
all
make[3]: Entering directory `/cygdrive/p/src/chk/epics/wex/myExampleApp/src/O.wi
n32-x86-cygwin'
make[3]: Leaving directory `/cygdrive/p/src/chk/epics/wex/myExampleApp/src/O.win
32-x86-cygwin'
n32-x86-cygwin'
Expanding dbd
/home/phoebus/NORUME/src/EPICS/base_R3_14_2_branch/bin/win32-x86-cygwin/dbExpand
.exe  -I . -I .. -I ../../../dbd -I /home/phoebus/NORUME/src/EPICS/base_R3_14_2_
branch/dbd -o ../O.Common/myExample.dbd ../myExampleInclude.dbd
Installing dbd file ../../../dbd/xxxSupport.dbd
mkdir ../../../dbd
Installing dbd file ../../../dbd/myExample.dbd
Installing dbd file ../../../dbd/xxxRecord.dbd
/home/phoebus/NORUME/src/EPICS/base_R3_14_2_branch/bin/win32-x86-cygwin/dbToReco
rdtypeH.exe  -I . -I .. -I ../../../dbd -I /home/phoebus/NORUME/src/EPICS/base_R
3_14_2_branch/dbd  ../xxxRecord.dbd ../O.Common/xxxRecord.h
Installing generated generic include file ../../../include/xxxRecord.h
mkdir ../../../include
gcc -c   -D_POSIX_THREADS -D_POSIX_TIMERS        -D_X86_  -DUNIX  -DCYGWIN32 -U_
WIN32   -pedantic  -O3  -Wall           -I. -I.. -I../../../include/os/cygwin32
-I../../../include -I/home/phoebus/NORUME/src/EPICS/base_R3_14_2_branch/include/
os/cygwin32 -I/home/phoebus/NORUME/src/EPICS/base_R3_14_2_branch/include
../xxxRecord.c
In file included from ../xxxRecord.c:15:
/home/phoebus/NORUME/src/EPICS/base_R3_14_2_branch/include/devSup.h:50:3: warnin
g: C++ style comments are not allowed in ISO C89
g: (this will be reported only once per input file)
../devXxxSoft.c
In file included from ../devXxxSoft.c:15:
ar -rc   libxxxSupport.a      xxxRecord.o devXxxSoft.o
ranlib libxxxSupport.a
Installing library ../../../lib/win32-x86-cygwin/libxxxSupport.a
mkdir ../../../lib
mkdir ../../../lib/win32-x86-cygwin
ranlib ../../../lib/win32-x86-cygwin/libxxxSupport.a
perl /home/phoebus/NORUME/src/EPICS/base_R3_14_2_branch/bin/win32-x86-cygwin/reg
isterRecordDeviceDriver.pl ../O.Common/myExample.dbd myExample_registerRecordDev
iceDriver > myExample_registerRecordDeviceDriver.cpp
g++ -c   -D_POSIX_THREADS -D_POSIX_TIMERS        -D_X86_  -DUNIX  -DCYGWIN32 -U_
../dbSubExample.c
../myExampleMain.cpp
g++ -o myExample.exe  -L/home/phoebus/NORUME/src/EPICS/base_R3_14_2_branch/lib/w
in32-x86-cygwin/ -Lp:/src/chk/epics/wex/lib/win32-x86-cygwin//                 m
yExample_registerRecordDeviceDriver.o dbSubExample.o myExampleMain.o    -lxxxSup
port -lrecIoc -lsoftDevIoc -ltestDevIoc -liocsh -lmiscIoc -lrsrvIoc -ldbtoolsIoc
 -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom      -lm
Installing binary ../../../bin/win32-x86-cygwin/myExample.exe
mkdir ../../../bin
mkdir ../../../bin/win32-x86-cygwin
32-x86-cygwin'
make[2]: Leaving directory `/cygdrive/p/src/chk/epics/wex/myExampleApp/src'
make -C Db install
make[2]: Entering directory `/cygdrive/p/src/chk/epics/wex/myExampleApp/Db'
mkdir O.Common
all
make[3]: Entering directory `/cygdrive/p/src/chk/epics/wex/myExampleApp/Db/O.win
32-x86-cygwin'
Installing db file ../../../db/dbExample1.db
mkdir ../../../db
Installing db file ../../../db/dbExample2.db
Installing db file ../../../db/dbSubExample.db
make[3]: Leaving directory `/cygdrive/p/src/chk/epics/wex/myExampleApp/Db/O.win3
2-x86-cygwin'
make[2]: Leaving directory `/cygdrive/p/src/chk/epics/wex/myExampleApp/Db'
make[1]: Leaving directory `/cygdrive/p/src/chk/epics/wex/myExampleApp'
make -C iocBoot install
make[1]: Entering directory `/cygdrive/p/src/chk/epics/wex/iocBoot'
make -C iocmyExample install
make[2]: Entering directory `/cygdrive/p/src/chk/epics/wex/iocBoot/iocmyExample'
elease.pl -a win32-x86-cygwin envPaths
make[2]: Leaving directory `/cygdrive/p/src/chk/epics/wex/iocBoot/iocmyExample'
make[1]: Leaving directory `/cygdrive/p/src/chk/epics/wex/iocBoot'
$ cd iocBoot/iocmyExample/
Norume@CTLPC20 ~/src/chk/epics/wex/iocBoot/iocmyExample
$ ../../bin/win32-x86-cygwin/myExample.exe st.cmd
< envPaths
epicsEnvSet(ARCH,"win32-x86-cygwin")
epicsEnvSet(IOC,"iocmyExample")
epicsEnvSet(TOP,"p:/src/chk/epics/wex")
epicsEnvSet(EPICS_BASE,"/home/phoebus/NORUME/src/EPICS/base_R3_14_2_branch")
cd p:/src/chk/epics/wex
dbLoadDatabase("dbd/myExample.dbd")
myExample_registerRecordDeviceDriver(pdbbase)
dbLoadRecords("db/dbExample1.db","user=NorumeHost")
dbLoadRecords("db/dbExample2.db","user=NorumeHost,no=1,scan=1 second")
dbLoadRecords("db/dbExample2.db","user=NorumeHost,no=2,scan=2 second")
dbLoadRecords("db/dbExample2.db","user=NorumeHost,no=3,scan=5 second")
dbLoadRecords("db/dbSubExample.db","user=NorumeHost")
cd p:/src/chk/epics/wex/iocBoot/iocmyExample
iocInit()
Starting iocInit
###  EPICS IOC CORE built on Nov 12 2003
###  EPICS R3.14.4 $$Name:  $$ $$Date: 2003/09/23 21:35:11 $$
iocInit: All initialization complete
epics> dbl
NorumeHost:aiExample
NorumeHost:aiExample1
NorumeHost:aiExample2
NorumeHost:aiExample3
NorumeHost:calcExample
NorumeHost:calcExample1
NorumeHost:calcExample2
NorumeHost:calcExample3
NorumeHost:compressExample
NorumeHost:subExample
NorumeHost:xxxExample
epics> dbpr NorumeHost:aiExample
ASG:                DESC: Analog input  DISA: 0             DISP: 0
DISV: 1             NAME: NorumeHost:aiExample              RVAL: 0
SEVR: MINOR         STAT: LOW           SVAL: 0             TPRO: 0
VAL: 4
epics> exit
Help about building a example under cygwin guobao shen
Prev: 3.13.6/3.13.8 Client/Server compilations with gcc Rosemary Alles
Next: Re: Help about building a example under cygwin Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Help about building a example under cygwin Andrew Johnson
Next: National Instruments VME-MXI-1 modules vs. modern VME CPU modules Eric Norum
