1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Building dm2k 2-5-3 on linux
To: [email protected]
Cc: [email protected]
Date: Fri, 21 Nov 2003 14:29:19 +1100
Hi Thomas,
I'm trying to build dm2k-2.5.3-source.tar.gz under Red Hat linux 9.0 and
EPICS 3.14.4 and am running into a number of problems which I am hoping you
can help with.  I've unzipped the file into my epics/extensions/src
directory and have run "make" without setting any environment variables
(that is, I'm trying to build using CA not CDEV.)
The first problem I run into is that the compilation of resourcePalette.c
fails because the symbol FLDNAME_SZ is not defined.  I notice that it is
defined in dm2kCdev.h but that this is not included into the compilation
when the environment variable DM2K_CDEV is not defined.  I have added the
definition of FLDNAME_SZ into dm2k.h and this worked.  Was this the correct
thing to do?
The second problem occurs later on where it tries to link in a library
named /usr/lib/libdld.1 when compiling and linking dm2k.  I'm hoping you
can tell me what this library is, where is comes from and if I need it.  Is
it an external piece of software that I need to install on my system?
After having encountered these problems, I noticed your comment in the
INSTALL file regarding Makefile.Unix and how it may not do what I'd expect.
I copied this file over Makefile.Host and tried again and ran into a number
of different errors regarding files not found in CONFIG_EXTENSIONS.
That's when I decided to give up.
Thanks in advance.
Steve Banks
Australian Synchrotron Project
Department of Infrastructure
Level 18, 80 Collins Street
Melbourne   VIC   3000
tel:  +613 9655 6303
fax:  +613 9655 8666
web: www.synchrotron.vic.gov.au
Re: Building dm2k 2-5-3 on linux Burkhard Kolb
Prev: RE: help! problems making in WIN32 Jeff Hill
Next: Linux -> PPC cross-compile of the Motor Record Andy Foster
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: help! problems making in WIN32 Eugene Tan
Next: Re: Building dm2k 2-5-3 on linux Burkhard Kolb
