1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: help! problems making in WIN32
To: [email protected]
Date: Fri, 21 Nov 2003 06:47:13 +0800 (WST)
Thanks Damian and Mark.
I've looked at the RELEASE and RULE files.  Everything was OK. I looked at
the output again, and I have no idea how the extra periods got into the
message. Cutting and pasting problem.
But I think I've found my problem. When I try to run the dbExpand line
independently I realised that this didn't work -
/cygdrive/c/epics/base-3.14.4/bin/win32-x86/dbExpand.exe -I . -I .. -I
.../../../dbd -I /cygdrive/c/epics/base-3.14.4/dbd -o O.Common/test.dbd
testInclude.dbd
While the following did work
.../../../dbd -I ../../../base-3.14.4/dbd -o O.Common/test.dbd
testInclude.dbd
For some reason the program dbExpand can't find base.dbd when I use the
static path "/cygdrive/c/epics/base-3.14.4/dbd" where as the relative path
definition works. This must be a cygwin thing. Any idea how to get around
this?
Cheers,
Eugene
 On Fri, 21 Nov 2003, LYNCH, Damien wrote:
> Hi Eugene,
> Have you noticed this part of the make output?
> > make[3]: Entering directory
> > `/cygdrive/c/epics/work/testApp/src/O.win32-x86-borland'
> > Expanding dbd
> > /cygdrive/c/epics/base-3.14.4/bin/win32-x86-borland/dbExpand.exe
> > -I . -I .... -I ..../../../dbd -I /cygdrive/c/epics/base-3.14.4/dbd -o
> > ../O.Common/test.dbd
> > ..../tes
> > tInclude.dbd
> It looks a little suspicious. I think it should be just two periods, not four. I am not sure where this command is made but start looking in base/configure/RULES.Db. Maybe there is something funny about the definition DBDFLAGS?
> Damien.
> > -----Original Message-----
> > From: Eugene Tan [mailto:[email protected]]
> > Sent: Thursday, 20 November 2003 5:38 PM
> > Subject: help! problems making in WIN32
> > I've managed to compile EPICS base 3.14.4 with Borland5.5 (freetools)
> > while using a CYGWIN environment, IE using CYGWIN's make and perl
> > utilities. No observervable problems there.
> > The problem comes when I'm trying to make the example generated by
> > ... <snip>
Prev: help! problems making in WIN32 Eugene Tan
Next: RE: help! problems making in WIN32 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: help! problems making in WIN32 Jeff Hill
Next: Building dm2k 2-5-3 on linux Steven . Banks
