1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Gateway 2_0_0_0Beta1
To: "Martin L. Smith" <[email protected]>
Cc: [email protected]
Date: Wed, 3 Dec 2003 09:16:25 +1100
Hi Marty,
Thanks for your reply.
Your comments about the contents of the gateway.restart and gateway.killer
files don't correspond to what I see.  Each of those files on my system
contain just one kill command.   The gateway.killer file contains a single
kill command which kills the parent (watcher?) process.  The
gateway.restart file contains a single kill command which kills the child
(gateway?) process.  This is how I understood it was supposed to work.
What's seems to be happening on my system is that when I run
gateway.restart, the gateway process is correctly killed, however the
watcher then creates two new processes so I end up with one more than I
should have.
Can I just confirm... are you using the 2_0_0_0Beta1 version or the
previous 1.3 version?
Steve Banks
Australian Synchrotron Project
Department of Infrastructure
Level 18, 80 Collins Street
Melbourne   VIC   3000
tel:  +613 9655 6303
fax:  +613 9655 8666
web: www.synchrotron.vic.gov.au
Hi Steve,
             I'm running the administration of 40 PV gateways on about 11
solaris machines and I don't have this problem. You should confirm that
the gateway.restart file contains the kill command to kill off the
server and the watcher processes. You can find this in the file
gateway.killer and it should be the last kill statement in there.
Also you should confirm that the PID in the kill statement is in fact
the PID of your PV gateways parent process.
Marty Smith
Argonne National Laboratory
Advanced Photon Source
Accelerator Systems Division
Controls Group
Prev: RE: EPICS Gateway 2_0_0_0Beta1 Jeff Hill
Next: Problems with solaris-sparc-gnu Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
