1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problems with solaris-sparc-gnu
To: <[email protected]>, <[email protected]>
Cc: <[email protected]>
Date: Tue, 2 Dec 2003 21:59:13 -0600
Folks,
I'm having some problems building EPICS 3.14 stuff on solaris-sparc-gnu.  I have built base 3.14.4 with no problems.  I have also built the EPICS example application, including the snc example, and the soft IOC works OK.
The problems I'm having are:
- An error linking the mpf2-4 test programs.  A C++ routine (Tcp::connect) which should definitely exist in the libmpf.so library is not being found at link time.
- I have built the 3.14 versions of the extensions ezca, EzcaScan and ezcaIDL with no problems.  However, when I try to use the resulting ezcaIDL.so from IDL on Solaris to do channel access it gives a bus error and crashes.
The version of g++ on my Solaris system is 2.95.3. The MPF problem does not happen on Linux (g++ 3.2.2) or Mac Darwin (g++ 3.3).  Do you think it is likely that these problems are gcc/g++ version related?  What versions of gcc/g++ have others used for building on Solaris, and has anyone built MPF 2-4 with it?
Prev: Re: EPICS Gateway 2_0_0_0Beta1 Steven . Banks
Next: Re: Problems with solaris-sparc-gnu Ben-chin K. Cha
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
