1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA FLNK
To: Steven Hunt <[email protected]>
Date: Fri, 05 Dec 2003 11:18:30 +0100
Steven Hunt wrote:
> Hi,
> In the example below should the second record be processed ? (epics 3.14.4)
> record(calc, "DEV:1") {
>   field(PINI, "YES")
>   field(CALC, "42")
>   field(FLNK, "DEV:2.PROC CA")
> record(calc, "DEV:2") {
>   field(CALC, "42")
> Thanks
> Steve
Hi Steven.
the problem is that a channel access put fails at PINI time.
Processing the first record afterwards will cause the second record
to properly process, too.
Is think this is a feature, not a bug. A record should not be accessible
by channel access before it is initialized. Otherwise all clients could see the
uninitialized values of the records.
Andreas
CA FLNK Steven Hunt
Prev: CA FLNK Steven Hunt
Next: Re: process function of record waveform and CA (caput, caget) Ben-chin K. Cha
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: scanRecord for 3.14 Marty Kraimer
