1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: scanRecord for 3.14
To: Marty Kraimer <[email protected]>
Cc: EPICS Tech-talk <[email protected]>
Date: Fri, 05 Dec 2003 17:18:49 -0500
We use the sscanRecord from synApps and look forward to it under R3.14.
Could this be unbundled and distributed like the motor software?
Ernest
SNS
On Fri, 2003-12-05 at 16:01, Marty Kraimer wrote:
> The next 3.14 release will support put callbacks for database channel access
> links. This is being done so that synapps can remove it's dependence on recDynLink.
> 3.13 and early versions of 3.14 has support for scanRecord. This was removed
> from 3.14 because it required recDynLink. Now that put callback links will be
> supported the scanRecord could be easily modified so that it no longer requires
> recDynLink.
> The question I have is does anyone use scanRecord?
> Synapps provides sscanRecord which provides more functionality than scanRecord
> so is scanRecord still needed?
> Marty Kraimer
Re: scanRecord for 3.14 John Maclean
scanRecord for 3.14 Marty Kraimer
Prev: RE: scanRecord for 3.14 Redman, Russell O.
Next: Re: scanRecord for 3.14 John Maclean
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: scanRecord for 3.14 Marty Kraimer
