1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Insertion Devices Control and EPICS
To: Rok Sabjan <[email protected]>, [email protected]
Date: Fri, 12 Dec 2003 05:32:09 -0700
Some options:
Use the hardware capability in the OMS card -
Requires modification to driver, device support and record support. Perhaps write an undulator record that accesses this synchronized move in the modified driver.
Modify the driver support to wakeup the database on each readback. The driver reads the motor position at 30 Hz. If there was analog input device support that posted this event, database logic could be used to wake up at 30 Hz while the motor is moving and verify that the difference in the gaps is constant or within tolerance. A stop to the motors if they are starting to diverge would occur within 40 msec. This would be a minimal change to the device support and driver and may still meet the requirements.
Bob
On Fri, 12 Dec 2003 13:38:17 +0100 Rok Sabjan <[email protected]> wrote:
Hello everyone!
I'm trying to prepare a proposal for ID control system at Diamond. During that time I have been asking some people some questions how this is currently managed in EPICS. To my surprise I found out that there was no clear way to solve this problem. I had a discussion with Tim Mooney and we were thinking of some possible solutions for the biggest problem - synchronous motor movement under EPICS. We have developed some suggestions, but I think it is time to broaden the discussion to tech-talk. There may be more people interested in such solutions and there are probably some people with some experience on the matter.
First let me remind everyone on the problem. We have two (or more) motors which we would like to move synchronously. This means to guarantee the movement will start and end at the same time. This is extremely important when changing the gap of an insertion device.
One may suggest that we should just wire the signal lines together (hardware solution) and use one signal line to control multiple motors, but we also want to move these motors independently. We may implement some logic (using FPGA or some other programmable logic) to multiplex this one signal line in one operation mode and use multiple signals for different motors in some other mode.
The OMS VME58 card, which is normally used in EPICS for motion control, supports such synchronized moves, but this is (to my knowledge and experience) not supported via EPICS motor record and device support. We should also provide some kind of sync record, which would take control of correspondent motor records (when instructed to do so) and would then perform the synchronized moves. Needless to say, there are a lot of design choices to identify and make on the behaviour of this record.
This mail is intended to identify people who have common interest for such a development in EPICS community. Definitely, we will have to make some modifications to the existing motor software if we decide to go through with any of these ideas. The idea is to make a general EPICS solution for such situations.
Cheers,
Rok
Bob Dalesio [email protected] 410 557 0297 Maryland 505 667 5643 Los Alamos (New Number) 505 699 1632 Cell Phone 505 667 6087 Our Secretary (Lisa Marie)
Re: Insertion Devices Control and EPICS Juraj Krempasky
Re: Insertion Devices Control and EPICS David Maden
Insertion Devices Control and EPICS Rok Sabjan
Prev: Software listing Ian Lenzen
Next: Insertion Devices Control and EPICS Rok Sabjan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Insertion Devices Control and EPICS Rok Sabjan
Next: Re: Insertion Devices Control and EPICS Juraj Krempasky
