1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Spurious link alarms generated?
To: "J. Frederick Bartlett" <[email protected]>
Date: Tue, 16 Dec 2003 09:15:44 -0600
SUMMARY OF PROBLEM
invalid.db contains the definitions
record(mbbo,"recordA") {
    field(OUT, "recordB.C PP MS")
record(calcout,"recordB") {
    field(INPB, "recordA.MASK NPP MS")
The problem is that when recordA is first processed recordB shows an alarm.
Let me present a solution first
Instead of the above use
record(mbbo,"recordA") { field(OUT, "recordB.C NPP NMS") field(FLNK,"recordB") ... }
Or even better
    field(INPC,"recordA NPP MS")
Note that the invalid.db has one more problem. recordB also has
    field(INPA, "devRecord NPP MS")
Until devRecord is processed it will cause recordB to alarm.
In devRecord just specify
    field(PINI,"YES")
Now for the gory details of why the original invalid.db does not work.
recordA processes. The mbboRecord support does the following:
    checkAlarms(pmbbo);
    if (pmbbo->nsev < INVALID_ALARM )
            status=writeValue(pmbbo); /* write the new value */
This happens BEFORE recGblResetAlarms. writeValue calls dbPutLink. dbPutLink uses NSEV to decide how to honor MS, which DOES NOT put recordB into alarm. Since OUT also has PP set recordB is processed. calcout calls dbGetLink to get a value from INPB. It uses SEVR to honor MS, which DOES puts recordB into alarm.
dbPutLink uses nsev instead of sevr because it knows that it is being called by the record containing the link. It want to pass it's records severity to the linked record.
dbGetLink gets the severity from the linked record. It uses SEVR because it doesn't know that it is called as a result of the linked record being processed.
What to do?
One idea would be to have dbGetLink check the PACT field and then use NSEV instead of SEVR. This is not a good idea since if it finds PACT true it has no idea about the state of the linked record. Did it call checkAlarms? Did it call recGblResetAlarms? It has no idea.
Thus I don't see that any changes to dbAccess will help.
Marty Kraimer
RE: Spurious link alarms generated? J. Frederick Bartlett
Prev: Re: Linking Unix Matlab-Compiled Programs against MCA Carl Lionberger
Next: RE: CA_UDP error message Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Spurious link alarms generated? J. Frederick Bartlett
Next: Software listing Ian Lenzen
