1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS R.314.4 for solaris-sparc-gnu build problem
To: Kevin Tsubota <[email protected]>
Cc: "tech-talk (E-mail)" <[email protected]>
Date: Mon, 05 Jan 2004 09:19:41 -0600
Looks like the solaris-sparc-gnu build will fail when
COMMANDLINE_LIBRARY is EPICS and the gnu libraries are
not in your LD_LIBRARY_PATH. Try adding the the following
line to configure/os/CONFIG.Common.solaris-sparc-gnu
OP_SYS_LDFLAGS += -R$(GNU_LIB) -L$(GNU_LIB)
to correct this problem.
If it works I will commit the change for the next R3.14 release.
Janet
Kevin Tsubota wrote:
Hi All,
I'm attempting to build EPICS R3.14.4 for solaris-sparc-gnu on a Solaris-8
host with the following versions of gcc, g++, and gmake:
kamaole{epics}187: gcc --version
2.95.2
kamaole{epics}188: g++ --version
2.95.2
kamaole{epics}189: gmake -version
GNU Make version 3.78.1, by Richard Stallman and Roland McGrath.
Built for sparc-sun-solaris2.7
Copyright (C) 1988, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99
        Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
My build is failing in the gmake of the base/src/toolsComm/flex directory
because of the following error:
ld.so.1: ../../../../bin/solaris-sparc-gnu/antelope: fatal:
libstdc++.so.2.10.0: open failed: No such file or directory
gmake[4]: *** [parse.c] Killed
gmake[4]: Target `install' not remade because of errors.
When I look at the make of antelope it is all good:
gmake[3]: Entering directory
`/local/epics/r3.14.4/base/src/toolsComm/antelope'
perl ../../../configure/tools/makeMakefile.pl O.solaris-sparc-gnu
mkdir O.Common
gmake -C O.solaris-sparc-gnu -f ../Makefile TOP=../../../..
T_A=solaris-sparc-gnu install
gmake[4]: Entering directory
`/local/epics/r3.14.4/base/src/toolsComm/antelope/O.solaris-sparc-gnu'
gmake[4]: Leaving directory
/usr/local//bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_XOPEN_SOURCE=500
-DOSITHREAD_USE_DEFAULT_STACK -DUNIX -DSOLARIS=8 -D__EXTENSIONS__
-ansi -O3 -w -D_NO_PROTO -I. -I..
-I../../../../include/os/solaris -I../../../../include ../closure.c
-I../../../../include/os/solaris -I../../../../include ../error.c
-I../../../../include/os/solaris -I../../../../include ../lalr.c
-I../../../../include/os/solaris -I../../../../include ../lr0.c
-I../../../../include/os/solaris -I../../../../include ../main.c
-I../../../../include/os/solaris -I../../../../include ../mkpar.c
-I../../../../include/os/solaris -I../../../../include ../output.c
-I../../../../include/os/solaris -I../../../../include ../reader.c
-I../../../../include/os/solaris -I../../../../include ../skeleton.c
-I../../../../include/os/solaris -I../../../../include ../symtab.c
-I../../../../include/os/solaris -I../../../../include ../verbose.c
-I../../../../include/os/solaris -I../../../../include ../warshall.c
/usr/local//bin/g++ -o antelope
-L/local/epics/r3.14.4/base/lib/solaris-sparc-gnu/
-R/local/epics/r3.14.4/base/lib/solaris-sparc-gnu closure.o error.o
lalr.o lr0.o main.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o
warshall.o -lCom Installing binary ../../../../bin/solaris-sparc-gnu/antelope
gmake[3]: Leaving directory
However a ldd shows that I'm missind libstdc++.so.2.10.0:
kamaole{epics}183: ldd antelope
        libCom.so.3.14 =>
/local/epics/r3.14.4/base/lib/solaris-sparc-gnu/libCom.so.3.14
        libstdc++.so.2.10.0 =>   (file not found)
        libm.so.1 =>     /usr/lib/libm.so.1
        libc.so.1 =>     /usr/lib/libc.so.1
        librt.so.1 =>    /usr/lib/librt.so.1
        libpthread.so.1 =>       /usr/lib/libpthread.so.1
        libsocket.so.1 =>        /usr/lib/libsocket.so.1
        libnsl.so.1 =>   /usr/lib/libnsl.so.1
        libdl.so.1 =>    /usr/lib/libdl.so.1
        libaio.so.1 =>   /usr/lib/libaio.so.1
        libmp.so.2 =>    /usr/lib/libmp.so.2
        /usr/platform/SUNW,Ultra-5_10/lib/libc_psr.so.1
        libthread.so.1 =>        /usr/lib/libthread.so.1
Other applications suffer from this problem as well, i.e. casw,
caRepeater... I could add it to my LD_LIBARY_PATH but I thought the default
config was to build things statically so the only thing that I changed in
the configuration was:
diff CONFIG.solaris-sparc-gnu.solaris-sparc-gnu
CONFIG.solaris-sparc-gnu.solaris-sparc-gnu.original
13c13
< GNU_DIR = /usr/local
GNU_DIR = /opt/gnu
A seperate problem which I encountered was ipAddrToAsciiAsynchronous.cpp was failing to compile due to: UNIT_MAX undefined error so I added the following:
diff src/libCom/misc/ipAddrToAsciiAsynchronous.cpp
src/libCom/misc/ipAddrToAsciiAsynchronous.cpp.original 29,30d28
< #include <limits.h>
What have I missed in my build?
Mahalo!
Kevin Tsubota
W.M. Keck Observatory
Prev: Re: EPICS time Marty Kraimer
Next: Re: Help with simple ioc response test app Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Python MegaWidgets (Pmw) and Blt Noboru Yamamoto
