Lei Ge wrote:
Dear All,
I have a question on how to use Pmw.Blt. We have installed Python2.1,
Pmw-1-2 and Blt2.4z in our Solaris 8. When I tried to use Pmw.Blt.Graph, I
got the following,
from Tkinter import *
import Pmw
master =Tk()
g=Pmw.Blt.Graph(master)
Traceback (most recent call last):
File "<stdin>", line 1, in ?
File "/usr/local/lib/python2.1/site-packages/Pmw/Pmw_1_2/lib/PmwBlt.py",
line 260, in __init__
Tkinter.Widget.__init__(self, master, _graphCommand, cnf, kw)
File "/usr/local/lib/python2.1/lib-tk/Tkinter.py", line 1756, in
__init__
self.tk.call(
TclError: invalid command name "::blt::graph"
Did I miss something?
Have you tested Blt itself, I mean without Python?
Run "make test" in BLT installation directory.
And also please check your Setup.local file in the Python/Modules
directory if library path to the Blt library/header are properly set.
Any comments are appreciated.
Ge
Noboru
- Python MegaWidgets (Pmw) and Blt Lei Ge
Re: ? initHookRegister() Marty Kraimer
<2004>
2025
2026
Re: EPICS R.314.4 for solaris-sparc-gnu build problem Janet Anderson
<2004>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
