1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS time
To: "Marty Kraimer" <[email protected]>
Cc: <[email protected]>
Date: Fri, 16 Jan 2004 14:10:26 -0600
Folks,
Back on Dec. 22 I reported:
> > Problem: The environment variable EPICS_TS_NTP_INET is
> supposed to allow me to specify the IP address of an NTP
> server.  My boot host (Windows) is not an NTP server, so I
> have used this environment variable to specify a valid NTP
> time server.  This works fine under 3.13.7.  However, when I
> boot the same system from 3.14.4 it does not work, I get an
> "iocClockSyncWithNTPServer: sntpcTimeGet S_sntpcLib_TIMEOUT
> error", and the "date" command says it's 1989.
Marty Kraimer replied on Jan. 5
> I do not understand why this worked under 3.13 but not under 3.14.
> How are you setting EPICS_TS_NTP_INET?
I did some more tests today, on both 3.13.7 and 3.14.4.  I booted with 3 configurations:
1) ntpd running on boot host
2) ntpd not running on boot host and EPICS_TS_NTP_INET not defined
3) ntpd not running on boot host and EPICS_TS_NTP_INET defined as follows:
putenv "EPICS_TS_NTP_INET=164.54.160.12"
where 164.54.160.12 is another machine that is running ntpd.
I found that things work as expected on both 3.13.7 and 3.14.4.  The date is correct in cases 1) and 3), and not correct in case 2).
My previous tests, when I reported the problem, were done at Brookhaven on a system I cannot access remotely, so I can't reproduce the problem.  The only thing I can think of is that the ntp server there is on another subnet and the IOC was not able to access it (I might have had the default route incorrect).
> If TIMEZONE is not defined on a vxWorks system epics looks
> for EPICS_TIMEZONE, which is defined in  <base>/configure/CONFIG_SITE_ENV/CONFIG_SITE_ENV
EPICS_TIMEZONE is not discussed in the Application Developer's Guide.  Should it be?
Python MegaWidgets (Pmw) and Blt Lei Ge
Prev: Behavior of tsLib, does TSinit get called by defaut. Thompson, David H.
Next: ? initHookRegister() Liyu, Andrei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS time Marty Kraimer
Next: Python MegaWidgets (Pmw) and Blt Lei Ge
