1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Behavior of tsLib, does TSinit get called by defaut.
To: [email protected]
Date: Fri, 16 Jan 2004 12:22:12 -0500
Has the behavior of  tsLib changed in 3.14.4?
I have a hardware system for distributing time, part of the SNS timing system.  The driver for the hardware has implemented the “ER” functions that TSinit looks for.  The ErHaveReciever functions returns 2 if it is called after the hardware is configured to receive time.  I have a printf in the function so I know when it gets called.  Before, I thought, TSinit() would get called during iocInit and after that subsequent calls would do nothing, I am looking at the code.  Now, it never seems to be called.  The strange thing is that syncNTP is started and if I call TSinit after iocInit then it leaves syncNTP running.  Before I could not figure out how to have syncNTP running as a backup to the hardware time.  Once TSinit is called then the IOC does not start using the hardware time but the output of TSreport changes to make it look like it does. ( I know this because the GPS receiver that it comes from is set on GPS time which is a few seconds fast.)  The date function seems to return the NTP time.
dht-ioc1>
dht-ioc1> date
2004/01/16 11:24:33.657598
value = 27 = 0x1b
The date function returned UTC-5 Hours
dht-ioc1> TSreport
Soft timing slave
Master timing IOC dead
No clock synchronization
Clock Rate in Hertz = 1000
Sync Rate in Seconds = 10
Master communications port = 18323
Slave communications port = 18322
Total events supported = 1
Request Time Out = 250 milliseconds
Broadcast address: 0.0.0.0:0
Master address: 0.0.0.0:0
value = 0 = 0x0
See if syncNtp is running:
dht-ioc1> i
  NAME        ENTRY       TID    PRI   STATUS      PC       SP     ERRNO  DELAY
tExcTask   excTask       1dfe740   0 PEND         1c649c  1dfe650       0     0
tLogTask   logTask       1dfbdb8   0 PEND         1c649c  1dfbcd8       0     0
tShell     shell         1b51ff8   1 READY        195c38  1b51c70  1c0001     0
tTelnetd   telnetd       1b58960   2 PEND         1907bc  1b587e0       0     0
tNetTask   netTask       1b89fc8  50 PEND         1907bc  1b89f08       0     0
snsUtilEven198793c       193e198  99 PEND+T       1c649c  193e0b8       0   300
tPortmapd  portmapd      1b573c0 100 PEND         1907bc  1b57240      16     0
syncNTP    19d6128       1945e38 109 DELAY        1951c8  1945d50  320001   220
cbHigh     19d6128       194b700 128 PEND         1907bc  194b630       0     0
value = 0 = 0x0
Now, call TSinit.
dht-ioc1> TSinit
iocClockRegister: iocClock already initialized
ErHaveReceiver() returns 2
value = 0 = 0x0
That called ErHaveReceiver in the driver.
dht-ioc1> TSreport
Direct timing slave
NTP sync with unix server
Total events supported = 2
Broadcast address: 160.91.227.255:18323
Event system has time directly available
value = 0 = 0x0
Date still returns UTC
dht-ioc1> date
2004/01/16 11:37:33.400696
If I call tsInit before iocInit then date returns GPS time. (13 seconds fast. )
## This drvTS initializer is needed if the IOC has a hardware event system
TSinit
value = 0 = 0x0
#v124sConfig 0, 0x9000, 0x3a, 7, 0.0
cd startup
value = 0 = 0x0
iocInit()
###  EPICS IOC CORE built on Nov 21 2003
###  EPICS R3.14.4 $$Name:  $$ $$Date: 2003/10/18 17:42:28 $$
Starting iocInit
value = 0 = 0x0
dht-ioc1> iocInit: All initialization complete
dht-ioc1> date
2004/01/16 12:10:14.312417
value = 27 = 0x1b
As you would expect:
ht-ioc1> TSreport
Direct timing slave
and syncNTP is NOT running.
The question is: Do I have to call TSinit to use the hardware time? Should the driver do that?  It looks for all in the world, looking at the code, that TSinit should get called somewhere from iocInit, at the very least when the first time stamp is required, but it does not seem to.  I thought that TSinit started syncNTP.
Am I missing something?
Prev: Can epics live simpler? Liyu, Andrei
Next: RE: EPICS time Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: ? initHookRegister() Liyu, Andrei
