Be sure to do a make in the <EXTENSIONS_TOP>/configure directory, then
all should be well.
This happens because the <EXTENSIONS_TOP> level Makefile is probably not
set-up to descend into the configure directory automatically.
Ernest
On Sun, 2004-03-07 at 00:02, Hammonds, John P. wrote:
> I am trying to build EPICS Extensions and have run into the following
> error in the SDDSepics directory. I can get past this by manually
> adding the path to the $(EPICS_BASE)/include and
> $(EPICS_BASE)/include/os/Linux to the gcc command in the O.linux-x86
> directory but have to do this for a few more files. I cannot seem to
> find the correct place to add the path to get this to compile from
> makefiles.
> make[3]: Entering directory
> `/net/iocapps/R3.14.5/extensions/IPNS1-0/src/SDDSepics/runcontrol/O.linux-x86'
> /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_XOPEN_SOURCE=500 -DOSITHREAD_USE_DEFAULT_STACK -D_X86_
> -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall
> -fPIC -I. -I.. -I../../../../include/os/Linux
> -I../../../../include ..../libruncontrol.c
> ../libruncontrol.c:130:20: tsDefs.h: No such file or directory
> ../libruncontrol.c:131:19: cadef.h: No such file or directory
> In file included from ..../libruncontrol.c:133:
> ../libruncontrol.h:74:19: alarm.h: No such file or directory
> ../libruncontrol.h:81: syntax error before "chid"
> ../libruncontrol.h:81: warning: no semicolon at end of struct or union
> ../libruncontrol.h:83: syntax error before "pv_user_chid"
> ../libruncontrol.h:83: warning: type defaults to `int' in declaration
> of `pv_user_chid'
> ../libruncontrol.h:83: warning: data definition has no type or storage
> class
> ../libruncontrol.h:85: syntax error before "pv_host_chid"
> ../libruncontrol.h:85: warning: type defaults to `int' in declaration
> of `pv_host_chid'
> ../libruncontrol.h:85: warning: data definition has no type or storage
> class
> ../libruncontrol.h:87: syntax error before "pv_pid_chid"
> ../libruncontrol.h:87: warning: type defaults to `int' in declaration
> of `pv_pid_chid'
> ../libruncontrol.h:87: warning: data definition has no type or storage
> class
> ../libruncontrol.h:89: syntax error before "pv_sem_chid"
> ../libruncontrol.h:89: warning: type defaults to `int' in declaration
> of `pv_sem_chid'
> ../libruncontrol.h:89: warning: data definition has no type or storage
> class
> ../libruncontrol.h:91: syntax error before "pv_desc_chid"
> ../libruncontrol.h:91: warning: type defaults to `int' in declaration
> of `pv_desc_chid'
> After I get past this set of errors I get another one:
> `/net/iocapps/R3.14.5/extensions/IPNS1-0/src/SDDSepics/logDaemon/O.linux-x86'
> /usr/bin/g++ -o logDaemon -L../../../../lib/linux-x86/ -L./
> -L/net/iocapps/R3.14.5/base/IPNS1-0/lib/linux-x86/
> -Wl,-rpath,/net/iocapps/R3.14.5/base/IPNS1-0/lib/linux-x86
> logDaemon.o -lLogD -lmdbcommon -lSDDS1 -lrpnlib -lnamelist -lmdblib
> -lCom -lz
> /usr/bin/ld: warning: libmatlib.so, needed by
> ../../../../lib/linux-x86//libmdbcommon.so, not found (try using
> -rpath or -rpath-link)
> /usr/bin/ld: warning: libfftpack.so, needed by
> /usr/bin/ld: warning: libmdbmth.so, needed by
> ../../../../lib/linux-x86//libmdbcommon.so: undefined reference to
> `mat_scmul'
> ../../../../lib/linux-x86//librpnlib.so: undefined reference to
> `random_2'
> `mat_trans'
> `dbesk0'
> `mat_invert'
> `K_cei'
> `gammaQ'
> `realFFT2'
> `betaInc'
> `gauss_rn_lim'
> `dbesi1'
> `p_materror'
> `dbesk1'
> `mat_zero'
> `rSigLevel'
> `E_cei'
> `dbesi0'
> Any clues.
> I am using SDDS 1.26 and SDDSepics 1.26 and Redhat Enterprise Linux
> 3.0.
> John Hammonds
> Data Acquisition Systems Manager
> Intense Pulsed Neutron Source
> [email protected]
> (630)252-5317
Ernest L. Williams Jr. <[email protected]>
- SDDSepics compile problem with 3.14.5 Hammonds, John P.
gtr1-2 for SIS3301 DMA error. Kiman Ha
<2004>
2025
2026
RE: SDDSepics compile problem with 3.14.5 Hammonds, John P.
<2004>
2025
2026
