This fixed my problem. Thanks Ernest.
John Hammonds
Data Acquisition Systems Manager
Intense Pulsed Neutron Source
[email protected]
(630)252-5317
> -----Original Message-----
> From: Ernest L. Williams Jr. [mailto:[email protected]]
> Sent: Sunday, March 07, 2004 7:02 AM
> To: Hammonds, John P.
> Cc: [email protected]
> Subject: Re: SDDSepics compile problem with 3.14.5
> Hi,
> Be sure to do a make in the <EXTENSIONS_TOP>/configure directory, then
> all should be well.
> This happens because the <EXTENSIONS_TOP> level Makefile is probably
not
> set-up to descend into the configure directory automatically.
> Thanks,
> Ernest
> On Sun, 2004-03-07 at 00:02, Hammonds, John P. wrote:
> > I am trying to build EPICS Extensions and have run into the
following
> > error in the SDDSepics directory. I can get past this by manually
> > adding the path to the $(EPICS_BASE)/include and
> > $(EPICS_BASE)/include/os/Linux to the gcc command in the O.linux-x86
> > directory but have to do this for a few more files. I cannot seem
to
> > find the correct place to add the path to get this to compile from
> > makefiles.
> > make[3]: Entering directory
> > `/net/iocapps/R3.14.5/extensions/IPNS1-
> 0/src/SDDSepics/runcontrol/O.linux-x86'
> > /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> > -D_XOPEN_SOURCE=500 -DOSITHREAD_USE_DEFAULT_STACK -D_X86_
> > -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall
> > -fPIC -I. -I.. -I../../../../include/os/Linux
> > -I../../../../include ..../libruncontrol.c
> > ../libruncontrol.c:130:20: tsDefs.h: No such file or directory
> > ../libruncontrol.c:131:19: cadef.h: No such file or directory
> > In file included from ..../libruncontrol.c:133:
> > ../libruncontrol.h:74:19: alarm.h: No such file or directory
> > ../libruncontrol.h:81: syntax error before "chid"
> > ../libruncontrol.h:81: warning: no semicolon at end of struct or
union
> > ../libruncontrol.h:83: syntax error before "pv_user_chid"
> > ../libruncontrol.h:83: warning: type defaults to `int' in
declaration
> > of `pv_user_chid'
> > ../libruncontrol.h:83: warning: data definition has no type or
storage
> > class
> > ../libruncontrol.h:85: syntax error before "pv_host_chid"
> > ../libruncontrol.h:85: warning: type defaults to `int' in
declaration
> > of `pv_host_chid'
> > ../libruncontrol.h:85: warning: data definition has no type or
storage
> > class
> > ../libruncontrol.h:87: syntax error before "pv_pid_chid"
> > ../libruncontrol.h:87: warning: type defaults to `int' in
declaration
> > of `pv_pid_chid'
> > ../libruncontrol.h:87: warning: data definition has no type or
storage
> > class
> > ../libruncontrol.h:89: syntax error before "pv_sem_chid"
> > ../libruncontrol.h:89: warning: type defaults to `int' in
declaration
> > of `pv_sem_chid'
> > ../libruncontrol.h:89: warning: data definition has no type or
storage
> > class
> > ../libruncontrol.h:91: syntax error before "pv_desc_chid"
> > ../libruncontrol.h:91: warning: type defaults to `int' in
declaration
> > of `pv_desc_chid'
> > After I get past this set of errors I get another one:
> 0/src/SDDSepics/logDaemon/O.linux-x86'
> > /usr/bin/g++ -o logDaemon -L../../../../lib/linux-x86/ -L./
> > -L/net/iocapps/R3.14.5/base/IPNS1-0/lib/linux-x86/
> > -Wl,-rpath,/net/iocapps/R3.14.5/base/IPNS1-0/lib/linux-x86
> > logDaemon.o -lLogD -lmdbcommon -lSDDS1 -lrpnlib -lnamelist
-lmdblib
> > -lCom -lz
> > /usr/bin/ld: warning: libmatlib.so, needed by
> > ../../../../lib/linux-x86//libmdbcommon.so, not found (try using
> > -rpath or -rpath-link)
> > /usr/bin/ld: warning: libfftpack.so, needed by
> > /usr/bin/ld: warning: libmdbmth.so, needed by
> > ../../../../lib/linux-x86//libmdbcommon.so: undefined reference to
> > `mat_scmul'
> > ../../../../lib/linux-x86//librpnlib.so: undefined reference to
> > `random_2'
> > `mat_trans'
> > `dbesk0'
> > `mat_invert'
> > `K_cei'
> > `gammaQ'
> > `realFFT2'
> > `betaInc'
> > `gauss_rn_lim'
> > `dbesi1'
> > `p_materror'
> > `dbesk1'
> > `mat_zero'
> > `rSigLevel'
> > `E_cei'
> > `dbesi0'
> > Any clues.
> > I am using SDDS 1.26 and SDDSepics 1.26 and Redhat Enterprise Linux
> > 3.0.
> > John Hammonds
> > [email protected]
> > (630)252-5317
> Ernest L. Williams Jr. <[email protected]>
gtr1-2 for SIS3301 DMA error. Kiman Ha
EtherNet/IP for AB SLC5/05 PLC. Kiman Ha
<2004>
2025
2026
Re: SDDSepics compile problem with 3.14.5 Ernest L. Williams Jr.
<2004>
2025
2026
