1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: about edm help menu
To: [email protected]
Date: Thu, 11 Mar 2004 10:40:07 +0000
For some reason the top makefile does not build the imagelib code. If you cd into edm/imagelib and run make it should build and install lib605432d2-f29d-11d2-973b-00104b8742df.so. To make sure edm recognises the library you must delete edm/setup/edmObjects and source the setup script edm/setup/setup.sh. This should fix the help the problem with help not displaying pngs and gifs, and also add png and gif options to the graphics menu.
Hope this helps,
Mike
Dr Mike Leech
Computer Systems Manager
Diamond Light Source Ltd.
Prev: RE: EtherNet/IP for AB SLC5/05 PLC (and FlexLogix) Rarback, Harvey
Next: rapid scans D. Peter Siddons
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
