Subject: |
RE: EtherNet/IP for AB SLC5/05 PLC (and FlexLogix) |
"Rarback, Harvey" <[email protected]> |
To: |
"'Kay-Uwe Kasemir'" <[email protected]>, "'john sinclair'" <[email protected]> |
Cc: |
"Ha, Ki M." <[email protected]>, "'[email protected]'" <[email protected]>, "Lessard, Luc" <[email protected]>, "Sebek, Jim" <[email protected]>, "Rafael, Fernando" <[email protected]> |
Date: |
Wed, 10 Mar 2004 17:36:10 -0800 |
Controllers,
> -----Original Message-----
> From: Kay-Uwe Kasemir [mailto:[email protected]]
> Sent: Monday, March 08, 2004 9:31 AM
> To: john sinclair
> Cc: Ha, Ki M.; [email protected]
> Subject: Re: EtherNet/IP for AB SLC5/05 PLC.
> On 2004.03.08 09:59, john sinclair wrote:
> > Kay,
> > Is this also true for FlexLogix I/O?
> Don't know FlexLogix I/O, but I'm afraid
> the EPICS driver for the ControlLogix 5000 PLC
> is really specific to the ControlLogix 5000
> and its CIP service codes 0x0A, 0x4C, 0x4D.
We were faced with the same dilemma at SSRL: we were given a FlexLogix interface to the SPEAR3 injection kickers, but had no time to develop the drivers to support the FlexLogix tags.
We were fortunate that we already had some ControlLogix PLCs and Kay's EtherNet/IP driver. We bought an EtherNet interface to the FlexLogix PLC, connected it to the EtherNet/IP interface on the ControlLogix chassis and with a bit of ladder logic and thanks to AB's support for EtherNet/IP across their latest line of PLCs, we could talk to the kickers through a ControlLogix PLC.
We are planning to do the same for some beamline SLC5/05s.
Ugly, but it worked for us!
--Harvey
> The ControlNet/EtherNet/IP specifications include
> an "Object Library".
> In there you find an "Identity" object.
> Any EtherNet/IP decide implements that.
> The EPICS driver for the Logix 5000 uses queries it
> to get the serial number of the Logix 5000 ENET module.
> There is a "Message Router" object:
> We use that to get from the ENET module to the Logix 5000
> controller (where the ladder logix runs).
> When I contact the MessageRouter on FlexLogix I/O
> the same way I contact the MessageRouter onthe Logix 5000
> ENET module, I'm pretty sure the response will be:
> "Invalid Path", because the path from the Logix 5000 ENET module
> to the controller in slot 0 of the Logix 5000 backplane
> simply doesn't exist on FlexLogix.
> Then there are "Discrete Input Point", "Output Point",
> "Analog Input Point" etc. objects:
> Maybe you can use those to access I/O points
> on any "EtherNet/IP" device.
> But I was't getting anywhere with them for the
> Logix 5000. And in order to read/write tags in
> the Logix 5000 ladder logic, which is what I
> ultimately wanted to do, I had to use the Logix-specific
> service tags.
> So talk about a device using "EtherNet/IP" and thus
> being compatible is just like me handing you
> the telephone number of my aunt in Germany:
> Your telephone is certainly compatible with hers,
> but I think the communication wouldn't go past a
> > "Hello?"
> < "Hallo?"
> > "Do you speak English?"
> < "Sprechen Sie Deutsch?"
> > "Hello?"
> < "Hallo?"
> - click -
> - Klick -
> > John Sinclair
> > On Monday 08 March 2004 11:13 am, Kay-Uwe Kasemir wrote:
> > > On 2004.03.08 02:24, Kiman Ha wrote:
> > > > Hello! Kay and Stephanie,
> > > > Last Feb, I asked about AB SLC5/05 processor for Ethernet TCP/IP EPICS
> > > > driver and support.
> > > > The AB Comapny people said SLS5/05 PLC processor support EtherNet/IP.
> > > Yes, it might support the common portion of the EtherNet/IP
> > > protocol, the part that's documented at www.odva.org.
> > > That will allow you to read the serial number of your SLC5/05's
> > > ethernet interface.
> > > In addition, you need the CIP service codes that are specific
> > > to your PLC, the ones that allow you to read/write tags
> > > or files or whatever the data of interest is called on the
> > > respective architecture.
> > > > I known your alread developed EtherNet/IP drivers and support for SNS
> > > > project.
> > > That EtherNet/IP driver package uses the CIP codes for the
> > > AB ControlLogix 5000 series as described in
> > > AB Publication 1756-RM005A-EN-E.
> > > The latter publication also lists SCL commands,
> > > but they are very different from the CIP service codes
> > > for the ControlLogix series.
> > > Control Logix uses CIP service codes
> > > 0x4C : read data
> > > 0x4D : write data
> > > 0x0A : multi request
> > > and all those adress string tags on the Logix5000.
> > > As far as I know, the SCL5 doesn't have string tags
> > > but uses file/element/subelement addressing.
> > > So I'm afraid those AB people who talked to you can
> > > recite "EtherIP" from some SLC5 brochure but don't
> > > really understand the protocol.
> > > This means that the ether-ip driver for the ControlLogix 5000 won't
> > > talk to the SLC5, and making it talk to the SLC5 would be a major deal,
> > > close to starting from scratch.
> > John Sinclair
drvIpac maintainer? Till Straumann
RE: about edm help menu Mike Leech
<2004>
2025
2026
<2004>
2025
2026
