1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: rapid scans
To: [email protected]
Date: Fri, 12 Mar 2004 18:01:29 +0100
D. Peter Siddons wrote:
What aproaches are people taking to performing on-the-fly scans? What I mean is, a scan in which one launches a motor move and reads a detector as the motor is moving, rather than the more typical step-scan.
Pete.
I presented a talk on how we do this at the powder diffractometer of the SLS Material Science Beamline at the EPICS meeting at Bessy in May 2002. My slides are probably still on the web somewhere.
During a scan, we have a program (data taker) running in the ioc. It is driven by watchdog interrupts to minimise timing jitter. This reads either the encoder or the motor step counter (depending on whether the motor has an encoder or not) and 6 scaler values directly from the VME registers to minimise overhead. The read frequency is specified by the user as a number of ticks with the tick rate of the ioc set to 4 msec.
The data taker buffers the data via a vxWorks pipe to a data writer and this, in turn, writes the data in ASCII SDDS format to an NFS-mounted file.
The whole thing is glued together with EPICS soft channels, medm panels and a python script.
An 8 hour run with a 10 Hz sample rate generates something like 25 Mbytes of data, if I remember correctly. The data is then rebinned offline.
David
                               [email protected]
     _/_/_/   _/   _/_/_/     Beamline Control Group, SLS Project
    _/       _/   _/         Paul Scherrer Institute
     _/_/   _/     _/_/     CH-5232 Villigen-PSI
        _/ _/         _/   Tel: +41 56 310 3616
   _/_/_/ _/_/_/ _/_/_/   Fax: +41 56 310 3294
rapid scans D. Peter Siddons
Prev: Building java from Makefile.Host Hayton, TG (Tim)
Next: Re: rapid scans rolf
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: rapid scans Tim Mooney
