1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: More CA questions
To: [email protected]
Date: Tue, 16 Mar 2004 22:38:08 +0100
Hello Jeff,
first, thanks for the detailed answers.
On Tuesday 16 March 2004 20:46, Jeff Hill wrote:
> If it isn't possible to easily rearrange your code to circumvent these
> difficulties then please send another email describing the situation in
> more detail. If the current situation is causing an unavoidable hassle then
> I will need to consider alternatives.
thanks for the ofefr, but as i wrote in my follow-up message, i already found
a nice way to circumvent this problem with almost zero overhead. The idea is
that the connection handler only needs to check wether the information is
already in place and if not provide it *by itself*. What i didn't realize at
first is that it can easily do so: it gets the properly initialized chid as
an argument and therefore is in exactly the same position as the routine that
called ca_create_channel when the chid is returned. So i try to initialize
the object in question (the thing i wanted to wait for in the handler) at
both places -- after ca_create_channel returns and as first action inside the
handler -- and whoever is first wins. It's completely symmetrical (and works
fine).
> > Is this also the case if CA is used multi-threaded, i.e.
> > initialized with the ca_enable_preemptive_callback flag?
> Yes, the behavior does not change if preemptive callback is enabled.
OK, i thought so; just wanted to be sure.
> > (2) Does a similar rule apply to ca_change_connection_event if
> > previously ca_create_channel was called with a NULL connection handler?
> The ca_change_connection_event() installs the new connection handler
> function pointer, but does not cause the function to be invoked. That
> occurs only when the connection state of the channel changes.
Ok.
> > Btw, ca_change_connection_event is nowhere mentioned in the new CA
> > client reference. I hope it was just forgotten and is not deprecated.
> As you have discovered, use of ca_change_connection_event() in
> multi-threaded applications can be problematic, and IMHO its not a high
> quality interface in single threaded situations either. Therefore, future
> use of this interface is being discouraged.
I see. If an actual *change* in the connection handler is required, this can
of course be done with a 'master' handler that calls a different routine for
doing the actual work.
However, without ca_change_connection_event the choice of notification method
if irrevocable: It cannot be changed once ca_create_channel has been called.
so maybe it is better to keep suporting this routine, if only so that the
application can change its mind about wether to wait explicitly inside
ca_pend_io or to be notified via callback. (Though, actually, i can't think
of an application where having this possibility is of any importance... and
one can always close the channel and reopen it with or without a handler. So
maybe it *is* ok to deprecate it.)
> > ...I have some difficulty infering what "must" and "using" means in this
> > case...
> I agree that this part of the manual could be improved so I changed it as
> follows:
> Connection Management
So, my latest assumption (that behavior of routines is defined but channel
status might be disconnected) was correct. Good. The text also answers a
question i didn't raise yet, but already had in my mind, namely, if the
connection state may also be polled using ca_state.
Thanks again and keep up the good work.
Cheers,
Ben
PS: I just stumbled over the next issue that gives me headaches, namely that
the default for application threads is to always create a separate client
context, instead of joining an existing one. It would be *very* nice if this
default behavior could be overridden somehow, maybe via some compile time
switch (like -DCA_DEFAULT_SHARE_CONTEXT) or some global configuration call or
whatever. Likewise, it would be nice if one could override the default flag
that is given to ca_create_context whenever it is called implicity, i.e.
change the default to ca_enable_preemptive_callbacks. At the moment i cannot
say exactly how critical these two issues are for me, since i am still
experimenting.
RE: More CA questions Jeff Hill
Prev: RE: More CA questions Jeff Hill
Next: Problems of Channel Archiver Wang Yanke
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS COllaboration Meeting Agenda Bob Dalesio
