We recently hooked up some Wago modules here to monitor some
thermocouples through ethernet connections. Since we were dealing with
several isolated monitoring locations, one of the things I wanted in the
driver was the ability to make sure the ethernet connection was intact
through the EPICS channel status. We're using the DESY modification of
the TRIUMF modtcp driver
(http://www-kryo.desy.de/documents/EPICS/DESY/Records/wagoModbusSup.html),
and the driver did not show any change of status with a break in the
TCP/IP connection, but some of the code appeared to show that the basic
mechanism was already there. Fiddling around with the code a bit, I
came up with this mod:
In modtcpRead(), change the line:
if (pPlc->pSock->tcpsFd == INVALID_SOCKET) return -1;
to:
if (pPlc->pSock->connecting || pPlc->pSock->tcpsFd ==
Similarly change modtcpWrite(). The timeouts are long, but the record
status does eventually go INVALID when the connection is lost, and then
recovers when it is reestablished.
Eric Williams
ALS Controls
Lawrence Berkeley Lab
Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modern VME CPU modules) Andrew Johnson
Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVME CPU modules) Kate Feng
<2004>
2025
2026
Re: et_wish mon problem Lei Ge
modbus+ Terry Carlino
<2004>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
